Frustrated - help :-) Power cable routing - MINI Cooper Forum
First Generation Interior & Ice
 2Likes
  • 1 Post By mike1967
  • 1 Post By englishbullterrier
post #1 of 5 (permalink) Old May 28th, 2019, 07:44 PM Thread Starter
englishbullterrier's Avatar
Local Time: 04:14 PM
Quoted: 4 Post(s)
Hi all, so frustrating.
I'm just finishing the installation of a Pioneer DAB/FM/CD/Aux head unit that included replacing the original antenna with a DAB antenna. I also had the roof lining removed for another project, so the antenna replacement was easy.
I've run a switched +12v to turn on a sub amp, and a pair of RCA's from the back of the head unit.
BUT, damned if I can find a way to route a power cable from the battery (via a fuse), through the firewall and back to the hatch area for the subwoofer.
Any help getting a cable from the battery in the engine compartment to the hatch area would be MUCH APPRECIATED
Ta in advance.............ebt
englishbullterrier is offline
post #2 of 5 (permalink) Old May 28th, 2019, 07:58 PM
Quoted: 663 Post(s)
i would run a power off fag lighter live as its something that never gets used and is fused and runs from the body control module so should not effect it from going to sleep and causing flat battery.. and also when car is off its off. another live could be where the factory tow electrics picks up its power prob behind the boot plastics somewhere,
englishbullterrier likes this.
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
post #3 of 5 (permalink) Old Jun 12th, 2019, 09:21 AM Thread Starter
Quoted: 4 Post(s)
Yep, did this in the end. Cigarette lighter is quite a heavy duty circuit and is fused. I'm only using a small amp and it's working fine. Thanks..............ebt
post #4 of 5 (permalink) Old Jun 12th, 2019, 10:06 AM
Quoted: 663 Post(s)
what you can do is run a suitable size fuse from the fag lighter circuit positive side to your add on then it protects your item better , just find out your add on's amps drawn rating ie fuse size
post #5 of 5 (permalink) Old Jun 12th, 2019, 11:17 AM Thread Starter
Quoted: 4 Post(s)
what you can do is run a suitable size fuse from the fag lighter circuit positive side to your add on then it protects your item better, just find out your add on's amps drawn rating ie fuse size
Done when installing !
mike1967 likes this.
Tags: , ,
