Mystery Coolant Leak - MINI Cooper Forum
post #1 of 7 (permalink) Old Jan 16th, 2019, 11:30 AM Thread Starter
Local Time: 02:59 AM
Quoted: 6 Post(s)
Garage
2003 R53 140,000 miles
Coolant "dumps" out over the head shield for the headers. Splash pattern indicates that it's coming from somewhere around the reservoir. It already has an aluminum aftermarket reservoir. I pulled the reservoir completely out. No cracks in the tank, and the inlet and outlet hoses are perfect. Replaced it, filled it with coolant, watched it get up to temp, reved the engine to get it hot, no leaks at all. Left for an hour and noticed a small puddle of coolant under the tank on the heat shield.
Now when the first leak happened on the way back from work, I would say that it dumped out vs leaked. I was able to park the car within 60 seconds and the reservoir was empty.
I figured, since the aftermarket tank doesn't come with a cap that the original owner just used the same cap. So the cap would be from 2003 and may have failed. To me this seemed like the only option. No leaks anywhere in the area, so the only option would be the old cap has failed and can't support the pressure anymore. Not the case. Purchased new cap. This morning the same thing happened, except on a lesser scale.
No chocolate milk either, so it's not leaking in the oil.
Complete mystery.
Someone please enlighten me. I'm going nuts over this.
rich0611 is offline
post #2 of 7 (permalink) Old Jan 16th, 2019, 01:44 PM
Quoted: 652 Post(s)
Complete mystery.
below link best way put a dose of ultra violet dye in water run it up use a special ultra violet light will find the leak easy in the dark, links below
https://www.ebay.co.uk/itm/Ring-RLD2...frcectupt=true
light torch
https://www.ebay.co.uk/itm/UV-ultra-...frcectupt=true
mike1967 is offline
post #3 of 7 (permalink) Old Jan 17th, 2019, 10:17 AM
Local Time: 10:59 AM
Australia Male View Hughesy1961's Classified Ads
I returned a new Aluminium tank as the supplied cap what not a pressure relief cap, just a straight screw on and the original had a different thread so could not be used on the new tank. A non pressure relief cap will cause over pressure in the system and may then causes leaks. I suspect this is where your problem lies. I went back to the original style tank which can be bought very reasonably. The leak could also be coming from the heater pipes that run into the cabin. Lastly you mentioned inlet & outlet pipes, The original only has an inlet pipe?
Hughesy1961 is offline
post #4 of 7 (permalink) Old Jan 17th, 2019, 12:50 PM Thread Starter
Quoted: 6 Post(s)
Garage
There are coolant hoses that go into the cabin??? I've never seen that. I'll have to check to see if that's a possibility.
The car has been running with the aluminum tank for the 2.5 years I've had it without issues until now. Also, the cap and replacement cap were both MINI OEM.
Naturally the tank would have a return coolant hose and an exit coolant hose.
rich0611 is offline
post #5 of 7 (permalink) Old Jan 17th, 2019, 12:58 PM
Quoted: 652 Post(s)
no point guessing what it could be only way to know for sure is to test it, ie by far best way is put a dye in it see where it comes out,, if it dont then head gasket sniff tester next test, link for this below, its all about a process and method of finding faults, no two jobs can be the same is best mind set to have
https://www.ebay.co.uk/itm/BT-3-BLOC...frcectupt=true
mike1967 is offline
post #6 of 7 (permalink) Old Jan 19th, 2019, 09:02 AM
There is also water pipes that run along the back of the engine down low which lead to the the oil heat exchanger to cool/warm the engine oil. The pipes are steel and mine had rusted through.
post #7 of 7 (permalink) Old Jan 26th, 2019, 11:27 AM Thread Starter
Quoted: 6 Post(s)
Garage
Resolved!
Ended up taking it over to Way at WMW. The low speed engine fan resistor was bad and there was a small leak due to a wrong clamp. The engine was getting hot enough for the coolant to boil over, but the stupid Mini temp gauge wasn't showing it.....
Needless to say, I ended up going with a scan gauge.
Thanks everyone!
rich0611 is offline
Tags: , , ,
Mystery water leak & non working temp gauge! Steve A General Discussion 3 Oct 4th, 2018 07:27 AM
Mystery exhaust leak jfrankjr General Discussion 5 Sep 28th, 2017 05:28 PM
Mini One R52 mystery disappearing coolant - PLEASE help! Jadekip First Generation MINI One 21 Sep 26th, 2017 06:07 PM
Oil Leak or Coolant leak MeanGreen7 First Generation MINI Cooper S 3 Feb 17th, 2014 04:17 PM
Radiator leak, Engine Mount leak classed as wear and tear or mechanical fault? alag20 First Generation Faults & Fixes 8 Jul 2nd, 2010 08:34 AM
