6 Speed gearbox can’t fill with oil - MINI Cooper Forum
post #1 of 3 (permalink) Old May 15th, 2019, 04:53 PM Thread Starter
Local Time: 10:55 AM
Quoted: 1 Post(s)
Hi I’ve just purchased a 2002 r53 and when doing a service I tried to do a gearbox oil change the previous owner looks like he as attempted to undo the oil fill plug and ruined the plug the drain one comes out ok,If I drain the oil is there any other way I can get oil into the box like through a speedo drive or other means
Dac0800 is offline
post #2 of 3 (permalink) Old May 15th, 2019, 05:05 PM
Quoted: 631 Post(s)
Originally Posted by Dac0800 View Post
Hi Iíve just purchased a 2002 r53 and when doing a service I tried to do a gearbox oil change the previous owner looks like he as attempted to undo the oil fill plug and ruined the plug the drain one comes out ok,If I drain the oil is there any other way I can get oil into the box like through a speedo drive or other means
you will be looking for reverse light switch on gearbox below link shows what you are looking for.
https://www.ebay.co.uk/itm/REVERSE-L...oAAOSwpF1bU9zv
will need one of these a fluid syringe tool so useful, handy for bleeding diesels and brake systems etc,
https://www.ebay.co.uk/itm/Gearbox-O...8AAOSwUKxYd6w9
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
post #3 of 3 (permalink) Old May 15th, 2019, 05:08 PM Thread Starter
Quoted: 1 Post(s)
Thanks I will give it a go
Dac0800 is offline
5 speed getrag gearbox to a 6 speed bjones First Generation MINI Tuning 8 May 6th, 2019 12:21 PM
R53 ‘04 MCS convertible sunroof won’t close TPJK Maintenance & MINI Care 0 Mar 15th, 2018 10:12 PM
getrag gearbox 5 speed to 6 speed bjones General Discussion 3 Nov 24th, 2013 03:12 PM
Hard Choice Drive Wife’s New MCS or My 99 C5 Vette wot99frc First Generation MINI Cooper S 1 Jan 19th, 2004 01:16 AM
What oil is factory fill in Cooper S? Ripsaw First Generation MINI Tuning 3 Nov 29th, 2002 10:31 AM
