ABS Fault - MINI Cooper Forum
post #1 of 4 (permalink) Old Nov 19th, 2018, 10:50 AM Thread Starter
Local Time: 06:54 AM
Quoted: 4 Post(s)
ABS Fault
Hi all,
Iím having an issue with our 2001 R50 Cooper Auto. The ABS and ASC lights have been on ever since we brought it after the seller hit a pot hole. The brakes work fine but MOT time is coming up soon so we need to get the fault rectified.
I have connected to the module using INPA and it returns a fault saying ĎInternal Processer Failureí. I canít remember the fault code off the top of my head (I can find it if necessary). Reading around there seems to be all different fixes for the fault, including replacing the module. The P/N on the circuit board side of the module is 6 758 803; but these seem to be very few and far between for replacement to be an option. Very occasionally the lights actually go out for approx. 10 miles or so it is intermittent.
Any ideas what the fault is likely to be?
dsgoody is offline
post #2 of 4 (permalink) Old Nov 19th, 2018, 12:07 PM
Quoted: 631 Post(s)
Originally Posted by dsgoody View Post
Hi all,
common abs module failure on gen 1 all you need to do is find a mini breaking same year and spec car, ie mini one 2002 find likewise, when its replaced it will self check and switch off lights, also before changing it check the multi-plug to it for corrosion
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
post #3 of 4 (permalink) Old Nov 20th, 2018, 03:16 PM Thread Starter
Quoted: 4 Post(s)
Thanks for the response. Can you confirm if the part numbers need to match up exactly? Trying to find one with the same part numbers is proving to be quite a challenge.
Are their any other known fixes we can try first?
dsgoody is offline
post #4 of 4 (permalink) Old Nov 20th, 2018, 05:02 PM
Quoted: 631 Post(s)
would check got power going to it check fuses, any abs module from a 2002 same spec car will fit, ie if its a cooper s get one from a cooper s or just a cooper same again, or mini one find a 2002 mini module and fit it,
mike1967 is offline
ABS Fault codes Che First Generation Faults & Fixes 1 Nov 30th, 2014 12:00 PM
ABS fault code oscar.cat Wheels, Tyres & Brakes 2 Jul 25th, 2009 04:16 PM
ABS fault, need help! ritchieb2001 First Generation Faults & Fixes 0 Apr 29th, 2007 09:12 PM
ABS DSC Fault tangodancer First Generation Faults & Fixes 34 Oct 6th, 2006 10:23 AM
abs & runflat fault after lowering... pro1 First Generation Faults & Fixes 0 Jul 29th, 2005 05:21 PM
