ABS Bleed - Which diagnostics tool? - MINI Cooper Forum
post #1 of 1 (permalink) Old Mar 30th, 2019, 03:04 AM Thread Starter
Local Time: 06:56 AM
Quoted: 3 Post(s)
Hi guys,
I was wondering what diagnostics tool you may have used in order to carry out an ABS bleed procedure?
I have a soft brake pedal in my 2002 R50 and I want to try an ABS bleed next. I have already replaced the master cylinder and bled the calipers with a pressure bleeder multiple times but the pedal remains soft.
I have heard that the Autel MaxiCheck Pro may do the trick.
Thanks in advance!
Tom
youngtractorboy is offline
Tags: , , , , ,
ABS Sensor and OBD Scan Tool for 2002 R50 in Australia Eversun First Generation Faults & Fixes 2 Dec 29th, 2017 05:25 AM
Anyone got a BMW tool 31 5 150 tool (R50/53 front suspension bush tool) ???? aw1234 General Discussion 1 Sep 24th, 2011 04:54 PM
ABS/Tyre Pressure light & Diagnostics zaychonok135 Maintenance & MINI Care 1 Mar 9th, 2011 09:27 PM
To bleed or not to bleed... Sushi Maintenance & MINI Care 13 Aug 5th, 2004 10:52 PM
Warninig!!!! My mini made me BLEED!!!! Adamo General Discussion 17 Aug 26th, 2003 03:51 PM
