2003 One D Cold Start Problem - MINI Cooper Forum
First Generation MINI One D MINI One Diesel 2003 - 2006
post #1 of 2 (permalink) Old Feb 11th, 2018, 06:46 PM Thread Starter
Mini2 Newbie
GustoA's Avatar
Local Time: 07:04 AM
Quoted: 1 Post(s)
Question 2003 One D Cold Start Problem
Hey guys, partners has a 2003 Cooper D 1.4 , its on 130k ish miles i believe but for a while she was having intermittent starting issues, car would start 9/10 times , few months down the line car wont cold start on its own unless we get a bit of easy start on there and it turns over straight away. Once the engine is warm car start no problem.
Im assuming it could be Glow Plugs? Any Suggestions? TIA
edit* car turns over, no signs of lack off battery power, everything comes on fine
GustoA is offline
post #2 of 2 (permalink) Old Feb 11th, 2018, 07:08 PM
Quoted: 631 Post(s)
any white smoke at start up if so glowplugs, also if you switch ignition on for 5 seconds then off and right back on again for 5 seconds do this over and over for around 5 times does car start, if does then chances are its just a couple of plugs gone down. if makes no difference then either all 4 are knackered or the glow plug relay has failed,
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
Mini Cooper 2003 cold start issue shiku84 First Generation MINI Cooper 2 Feb 3rd, 2012 04:29 PM
Won't start.......................NOT cold start issue Rwatts4mini First Generation Faults & Fixes 2 Nov 5th, 2011 01:16 PM
My cold start issue is now a warm start issue FrenchCori First Generation Faults & Fixes 0 Mar 31st, 2006 10:39 PM
Cold, cold cold (frozen gearbox problem) MINIHAHAHA First Generation Faults & Fixes 3 Jan 21st, 2003 01:32 AM
Will not start period....NOT Cold Start Issue Silly First Generation Faults & Fixes 31 Aug 5th, 2002 02:35 PM
