Few Problems - MINI Cooper Forum
 2Likes
  • 1 Post By mike1967
  • 1 Post By NigelK
post #1 of 3 (permalink) Old Jul 6th, 2018, 03:03 PM Thread Starter
Local Time: 05:26 AM
Quoted: 10 Post(s)
Ireland Male
Few Problems
Just bought a R53 Jcw Saturday, have just got it back from getting the brake pads replaced. I never properly drove it until today.
One problem that kinda scares me is when I was up a high speed, 160kmh or above, only briefly I could get a burning smell! Any idea on what that could be?
I also know there is an oil seal that need replacing, maybe that could be the reason? The mechanic said the oil seal has it be got from manufacturer, so just ring a dealer and get them to get it?
This could be nothing and just normal for it, but i was sitting in the car getting it washed and while idling the rpm was going up and down a tiny bit causing the car to shake a little. This could be normal just making sure!
Thanks.
OisinMurray is offline
post #2 of 3 (permalink) Old Jul 6th, 2018, 03:37 PM
Quoted: 654 Post(s)
Thanks.
did he say which oil seal, as there are two that are a big job to replace, ie rear crankshaft oil seal, or gearbox input oil seal both with need the gear box removing, if oil leaking from under between the bell housing and engine block and is dripping down it will get pushed up under the car and ht the exhaust this will give a oil burning smell, as for idle hunting up and down so many things can cause this, first off a smoke test on the inlet pipe work see if any cracks of holes in it, it thats passes then diagnostic scan see whats hidden away, if no codes then live data run see what 02 sensor is doing and boost etc and also will show any misfires etc, common things are 02 sensors throttle bodys super charger bypass valve thats the little lever vacuum controlled valve on the ss can stick worth first off wd40 it all over and work it in and out with hand or screw driver
OisinMurray likes this.
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
post #3 of 3 (permalink) Old Jul 8th, 2018, 12:30 AM
Quoted: 481 Post(s)
England Male
Good stuff from Mike. First off, I'd clean/power wash it off underneath, sump etc. get it really clean and then check to see where it is getting oily. Mine looked awful when I got it, at 97,000 miles. Power washed, actually not leaking too badly ..... for an R53. This is it at its annual MOT (as it was up on the ramp) at 106,000 miles in April this year. I have done nothing since buying it about fixing any oil leakage.
Second, make sure the oil is topped up and keep track of how much it is using - which could be two ways, burning or leaking.
Incidentally, I've found it incredibly difficult to read the dipstick, especially when the oil is fresh. So I've modded it. Pics. Turns out mine is overfull currently (but with the yellow tip I couldn't tell).
ID:	225385   Click image for larger version
ID:	225387   Click image for larger version
mike1967 likes this.
NigelK is offline
My r56 MCS - few problems drbsheffield Second Generation MINI Cooper S 12 Dec 4th, 2009 01:15 PM
A few little problems Matt_20 Second Generation Faults & Fixes 5 Jan 16th, 2009 12:31 PM
A few problems - Opinions Please musv First Generation Faults & Fixes 4 Apr 27th, 2007 06:01 AM
Mini S, Few Problems Sean84 First Generation Faults & Fixes 6 Jul 21st, 2006 03:58 PM
Problems, Problems, and Problems dxbmini First Generation Faults & Fixes 3 Oct 12th, 2004 12:43 PM
