Mini Cooper R56 Radio Problem - MINI Cooper Forum
post #1 of 9 (permalink) Old Apr 1st, 2013, 05:38 PM Thread Starter
Local Time: 08:03 AM
Quoted: 1 Post(s)
hello everyone i have a mini cooper 56 reg (2006 November model) and a few weeks ago i was listening to the radio and it just cut out and made a noise (like a thud) then some times it would come back on but not for long.
no i am unable to turn the radio on and the led display wont come on as well.
i have taken the radio out and was wondering if anyone had any suggestions ???
thanks
Curtis
Curtisblythe is offline
post #2 of 9 (permalink) Old Apr 23rd, 2014, 01:45 PM
Male
thanks
Curtis
Did you ever find out the problem? I have a 08 r56 n it started to do the same, I was wondering if you diagnosed the problem.
gm_MiniCoopsta is offline
post #3 of 9 (permalink) Old Sep 17th, 2014, 05:01 PM
Local Time: 09:03 AM
Anyone ever solve this? Couple of threads on the same vein with no answers...
Our mini has just done exactly this. Driving along, stereo fine, turn the car off and go to work- come back to a dead stereo.
Checked all fuses, including engine bay fuse and the rear of the stereo. LED display dead, only thing it will do is eject/accept a cd.
Dooper09 is offline
post #4 of 9 (permalink) Old Feb 25th, 2015, 12:51 PM
Registered User
anyone come up with a solution yet?
I've had a similar issue with my R56 Radio. Turned car off and locked it but the radio was stuck on. Eventually it went off, but now the radio is stuck on the same station and i can't change to CD or eject.
babybel is offline
post #5 of 9 (permalink) Old Feb 26th, 2015, 10:22 AM
camonixo's Avatar
Quoted: 1 Post(s)
Hi, I have a r53 '04 and I had a similar problem,my radio stopped and displayed 'phone' the system hasn't got a blue tooth... yes my cd would open and load but nothing else, I took it to the garage and they say its a radio failure and either send to manufacture for repair or replace it....hope this helps..
camonixo is offline
post #6 of 9 (permalink) Old Feb 26th, 2015, 10:52 AM
Quoted: 53 Post(s)
If the garage has looked at it and confirmed it is a radio fault then so be it, but you can accidentally select mute or press the phone symbol on the steering wheel which switches the speakers off for when you have the phone facility and this still works even if theres no phone facility fitted.
The Nun is offline
post #7 of 9 (permalink) Old Oct 25th, 2015, 06:02 PM
Just to respond to this - our stereo was dead. I suspect the Amp died in the HU. I bought one from a mini breakers in Nuneaton (top guy) and he coded it for me to get the aux in to start working.
Dooper09 is offline
post #8 of 9 (permalink) Old Jun 11th, 2019, 04:08 AM
thanks
Curtis
Hi
I am having the same issue. All fuses are working, including the one behind the radio. Did you find a solution?
Mati is offline
post #9 of 9 (permalink) Old Jun 11th, 2019, 04:10 AM
Any luck about this issue? I have the same problem. Thanks
Mati is offline
