Finding Final Stage (Hedgehog) Resistor - MINI Cooper Forum
post #1 of 26 (permalink) Old Jul 29th, 2014, 08:48 PM Thread Starter
Local Time: 08:45 AM
Quoted: 1 Post(s)
My Mini Coopers auto climate control has been playing up for months now. The heater and air conditioning works however the fan speed doesn't increase to blow the air into the car.
Having doing a lot of research and speaking to a Mini mechanic I know the final stage resistor is at fault and I now have a replacement. However, I cannot find its location in my car. I've watched a video on someone replacing one and seen a couple photographed step-by-step instructions, but I just can't find it.
If anyone can help I'd be very grateful.
crackernibbles is offline
post #2 of 26 (permalink) Old Aug 2nd, 2014, 09:33 PM Thread Starter
Quoted: 1 Post(s)
bump
post #3 of 26 (permalink) Old Aug 13th, 2014, 05:02 PM
Quoted: 1 Post(s)
hi,just had a quick look in my haynes manual and it ses its in the drivers side footwell,disconnect wiring plug,remove 1 torx screw and pull it out....you hope.....
rob955triumph is offline
post #4 of 26 (permalink) Old Aug 13th, 2014, 06:38 PM
Damned
Restyle's Avatar
Local Time: 07:45 AM
Quoted: 6 Post(s)
United Kingdom Male View Restyle's Hyper Blue & White 1st Gen MINI Cooper S Profile View Restyle's Classified Ads
Had mine replaced a couple of weeks ago when the fan lost the 1st 2 speeds.
Although It was done by the mechanics at MiniMatt, I was watching where they went as I was confused of its location myself.
So, Drivers side footwell - reach up almost to dash height behind the 'central heating unit block' & its attached by a torx screw somewhere around there.
There seems to be a couple of designs of them, although its called a resistor, the components looked as though they were part of a variable stabilised voltage setup unit.
Sorry for being a tad vague but at least you know the roundabout region to have a feel around now
Restyle is offline
post #5 of 26 (permalink) Old Aug 14th, 2014, 11:33 AM Thread Starter
Quoted: 1 Post(s)
Thank you both for ypur replies, I came across instruction once that showed it in the footwell about level with the climate control, but all i have there is one plug of wires for something else. Will try and look up where Restyle said and see if i have any luck (Hopefully!!)
post #6 of 26 (permalink) Old Aug 19th, 2014, 03:57 PM
Quoted: 1 Post(s)
good luck anyway,if bmw had any sense they would have put the resistor in a better position,i had to change my e46 330ci resistor 4 times cos its such a big problem with them,but what a git of a job!!...you need to be harry houdini....and now im just doing my supercharger oil!!!..hahahahahaha.....i cannot believe how much of the car you have to dismantle...just for 6 oz of oil,unbelieveable bmw....bad design indeed..so good luck mr.c/nibbles..enjoy......Rob.
post #7 of 26 (permalink) Old Nov 26th, 2014, 05:37 PM Thread Starter
Quoted: 1 Post(s)
Still had no luck, its being a real issue now that its winter and the screen won't de-mist.
Don't know what to do now...
post #8 of 26 (permalink) Old Nov 26th, 2014, 06:39 PM
Damned
Restyle's Avatar
Quoted: 6 Post(s)
Originally Posted by crackernibbles View Post
Still had no luck, its being a real issue now that its winter and the screen won't de-mist....Don't know what to do now...
Do you mean youve had no luck finding the 'resistor', or that you fou found it but it wasnt at fault?
If the former, why not try reaching under the dash with camera & take a picture of the area to the side of the central speedo on drivers side, & we'll try & point out the 'resistor' holding screw.
Restyle is offline
post #9 of 26 (permalink) Old Nov 27th, 2014, 05:07 PM Thread Starter
Quoted: 1 Post(s)
I cannot locate it. I've looked in the footwell to the left where they normally are and i have a blank bit of plastic and not a space where it should slot in.
I've also heard of it being in the glove compartment, mine is not.
I will try and get a photo ASAP as its getting incredibly annoying with the car steaming up, and having no air come in the car unless its moving.
Thanks for your reply.
post #10 of 26 (permalink) Old Nov 28th, 2014, 02:02 PM Thread Starter
Quoted: 1 Post(s)
Pictures
I've managed to get some pictures from the drivers footwell. The first is the left side and the second is of the right. On the second you can see the gap where normally the hedgehog would be connected.
I really appreciate any help with the issue.
ID:	180770   Click image for larger version
post #11 of 26 (permalink) Old Nov 28th, 2014, 08:04 PM
Damned
Restyle's Avatar
Quoted: 6 Post(s)
... On the second you can see the gap where normally the hedgehog would be connected.
Ive just had a look on REALOEM at the resistors location, & it would appear that you are correct in that your 2nd picture shows where the resistor used to be.
So, during sometime in the cars lifetime, we can assume that the resistor failed - & it was looked at, but not replaced.
So all youve got to do now is go to your local freindly MINI dealer armed with the part number shown in the diagram & ask them nicely to fit it for you.
Ta Dah!!
Restyle is offline
post #12 of 26 (permalink) Old Nov 28th, 2014, 11:58 PM Thread Starter
Quoted: 1 Post(s)
Thank you so much for looking. I bought he resistor months ago thinking it would be a simple replacement.
Looks like I'll need the wiring installed to connect it up.
I'll prepare my wallet......
post #13 of 26 (permalink) Old Nov 29th, 2014, 12:08 PM
Damned
Restyle's Avatar
Quoted: 6 Post(s)
...Looks like I'll need the wiring installed to connect it up.
Cant see any reason why anyone would permanently remove its connector, I would assume its just been tucked out of the way.
Id just give a gentle tug to any cables you can see or feel in the area, & hope that the 'missing one' with a connector comes loose.
Restyle is offline
post #14 of 26 (permalink) Old Nov 29th, 2014, 07:33 PM Thread Starter
Quoted: 1 Post(s)
Now i've seen this wiring diagram, I think the wiring next to the empty resistor hole is a bodge job. Haven't seen that wiring that i've pictured on any other mini. And somehow whoever had the car before me has wired this up in place of the resistor??
post #15 of 26 (permalink) Old Nov 29th, 2014, 09:28 PM
Damned
Restyle's Avatar
Quoted: 6 Post(s)
Just remembered I had the Haynes manual gathering dust on a shelf - & found the heater blower circuit.
According to that, it is an actual resistor bank & not a preset voltage regulator, but anyway, in order just to get something working, you could put a 12 volt feed directly onto the solid red wire (marked Rt in diagram below) that feeds the blower motor, & you should get full fan power output.
At least this would test that the blower motor actually works, & if it does, then you can go about sorting the wiring properly.
Keep us updated on your progress
Restyle is offline
R53 stage 1 fan resistor Aaron_burr First Generation Faults & Fixes 2 Apr 12th, 2013 03:05 PM
