Dog chewed wiring - MINI Cooper Forum
post #1 of 2 (permalink) Old Dec 16th, 2015, 08:26 AM Thread Starter
Local Time: 05:22 PM
New Zealand Dog chewed wiring
Hi all. I have a 05 Cooper S R53 and after installing new Pad's rotors and sensors my dog has decided to chew the 2 cable connections ie Blue and black clip connections in front of the rear right side wheel. The blue connector is the brake pad sensor cable and I'm guessing the black connector was for the tyre pressure sensor and ABS brakes. Any ideas as to how I should attack fixing this. Should I just hard wire them back together or replace all the lines and cables. Any thought's would be appreciated. Thank you.
Coxy007 is offline
post #2 of 2 (permalink) Old Dec 16th, 2015, 09:38 AM
Local Time: 06:22 PM
Quoted: 120 Post(s)
Take your dog to the vat and have it put to sleep.
k3fus is offline
Tags: ,
driving lamps wiring to xenon headlights cprcooper Second Generation MINI Exterior 18 Sep 19th, 2016 10:51 PM
2008 Cooper D Wiring Loom - Reverse Switch wju182 Second Generation Faults & Fixes 2 Aug 5th, 2015 02:58 AM
Problems installing heated seats retro fit wiring loom - Please help !!! aveze First Generation Interior & Ice 1 Nov 26th, 2012 09:28 PM
