lowering - MINI Cooper Forum
post #1 of 6 (permalink) Old Nov 10th, 2018, 12:57 PM Thread Starter
Local Time: 07:28 PM
Quoted: 2 Post(s)
lowering
hi , just got my first mini cooper s jcw, 2007 , need some advice please , it has 17" wheels at the mo , is it better to buy new 18" wheels or lower by say 20 mm, any advice greatly appreciated , also where is the best place to buy mini driving spots , went to my local mini dealership , they said i needed new grille as well and quoted me 800 odd for the lights plus fitting , TIA
kepsyboy is offline
post #2 of 6 (permalink) Old Nov 10th, 2018, 02:37 PM
cristo
cristo's Avatar
Local Time: 03:28 PM
Quoted: 37 Post(s)
United States Male View cristo's Hot Chocolate & Silver 2nd Gen MINI John Cooper Works Clubman Profile
Garage
Not much suspension travel in MINIs, so only plus for lowering is looks.
I think the 17 inch wheels work better overall than 18 inch in most cases.
What model tires do you have now, and do you need summer, all seasons,
or summer and winter based on your location's climate and preferences?
cristo is online now
post #3 of 6 (permalink) Old Nov 10th, 2018, 03:27 PM
Quoted: 631 Post(s)
cheapest way for spots is find one breaking complete with the special brackets, as for the grill dremel out two slots for brackets to poke through works, will need extra long torx tool for the small self tappers used,, big issue will come when wiring them in will need to factory wiring harness and switch on via body control module for proper factory fitment, or two relays and run a signal wire to the high beam head light bulbs wires. and a inline fuse from live feed off aux supply will work..
as for lowering them hmmm if you have lots of speed ramps where you live i would leave well alone, poly bush itis a nice mod maybe koni adjustable s, as for wheels and tyres what ever you add wheel size you will need to reduce profile of tyre, this changes a fairly compliant ride in to a more crashy and will track in every bump and groove in the road,,,
also lowering lowers the sump and puts in the way of anything that sticks up in the road as sump is a in line or slightly lower than the front subframe its just a bad day waiting to happen.
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
post #4 of 6 (permalink) Old Nov 10th, 2018, 04:45 PM Thread Starter
Quoted: 2 Post(s)
hi christo , thanks for the reply , much appreciated , i currently have ronal r17 split rims , which i dont particually like the tyres are toyo proxies , i will need a all season tyre , am looking for wheels also , many thanks , steve
kepsyboy is offline
post #5 of 6 (permalink) Old Nov 10th, 2018, 04:56 PM Thread Starter
Quoted: 2 Post(s)
thanks Mike , very informative reply think i will stay with the 17" then , will poly bushes all round improve the ride ,would still like to lower maybe 30mm max poss say 20mm , , what do you suggest , TIA
kepsyboy is offline
post #6 of 6 (permalink) Old Nov 10th, 2018, 05:29 PM
Quoted: 631 Post(s)
https://www.ebay.co.uk/itm/H-R-Perfo...7dt:rk:14:pf:0
above link not bad value come from a road race company. some other list below
https://www.ebay.co.uk/itm/H-R-Sport...3024:rk:1:pf:0
https://www.ebay.co.uk/itm/Eibach-Pr...frcectupt=true
or if were me and cost not a issue below link with shocks
https://www.ebay.co.uk/itm/Stance-St...r3s:rk:22:pf:0
https://www.ebay.co.uk/itm/BC-Racing...4Ar:rk:52:pf:0
lowering cooper s lowering W1 2OES First Generation MINI Suspension 11 Jan 17th, 2008 06:37 PM
Lowering kit with 18's? Bobcruchett First Generation MINI Suspension 9 Oct 25th, 2002 04:16 AM
How to install lowering springs? Keith First Generation MINI Suspension 3 Apr 7th, 2002 02:09 PM
lowering springs scott shand First Generation MINI Suspension 12 Apr 3rd, 2002 05:11 PM
regarding lowering/springs etc mini mucker First Generation MINI Exterior 0 Feb 27th, 2002 10:46 PM
