LED headlight bulb conversion on the 2014 Mini 3-door hatch - MINI Cooper Forum
post #1 of 2 (permalink) Old May 14th, 2019, 03:13 AM Thread Starter
Rayys922
Local Time: 04:11 PM
Philippines Male
Looking for a specific brand of LED bulb with canBus that can be replaced on the stock H4 halogen headlight bulb of the 2014 Mini 3-door hatchback (non "S")? Any link is highly appreciated!
RayysFC922 is offline
post #2 of 2 (permalink) Old May 14th, 2019, 09:38 AM
knt
Quoted: 52 Post(s)
Have you checked to see if it's legal in your location to do LED/HID conversion?
Even LEDs with canbus will certainly give you some sort of problems, will most likely have to disable some headlight monitoring via app or software.
Using LEDs bulbs as headlight might not give you the desired beam pattern and thus making it worse than the original bulb.
Try searching on YouTube for videos about LEDs headlight bulb.
Have you tried using super brighter standard bulbs?
knt is offline
H13 headlight conversion to LED Gx278612 MINI Clubman 0 Aug 16th, 2018 10:40 PM
Brands Hatch Mini Festival 2014 Photos mab01uk Mini Events 9 May 14th, 2014 10:47 PM
Bulb Warning - Which Bulb is faulty ckxion Second Generation Faults & Fixes 3 Dec 29th, 2012 01:45 PM
Indicator bulb warning bulb which fixes itself !!! as5606 Second Generation Faults & Fixes 3 Dec 11th, 2011 02:45 PM
