2004 Mini r50 Electrical - MINI Cooper Forum
post #1 of 3 (permalink) Old May 19th, 2019, 03:14 PM Thread Starter
Local Time: 02:17 AM
Hi All.
Recently my mini started playing up , the instrument lights and noise would not work when the indicators were on ( but the actual indicators still worked). the speedo and revo back lighting does not work , The lower panel and heated screen switch did not light and when turned off and locked , the rear lights stay on.
Changed body control module 3 times , fitted 2 different main ecu units and 2 alarm module units .
Cleaned and checked all plugs , fuse boxes and earth points .
Worked well for 2 days , and then did it again.
sometimes it resets to working by itself , then goes off again .
Any ideas anyone , as I am at the end of my tether with this problem .
I have not found anything that looks obviously broken.
Duncan.
dunc2504 is offline
post #2 of 3 (permalink) Old May 20th, 2019, 01:01 PM Thread Starter
Anyone ?
dunc2504 is offline
post #3 of 3 (permalink) Old May 20th, 2019, 02:05 PM
Quoted: 4 Post(s)
It does sound like an earthing issue. I would check around the steering column area for earth straps and make sure they are sound.
Gerry
pheasant_plucker is offline
2002 R50 Mini Cooper Electrical Issues alanlush First Generation Faults & Fixes 2 Mar 24th, 2019 06:26 AM
Mini r50 electrical problems Speshmcm666 First Generation Faults & Fixes 1 Aug 3rd, 2017 10:02 PM
2004 Mini Cooper S Electrical Problem Jubal First Generation MINI Cooper S 3 Sep 8th, 2015 02:46 PM
R50 electrical buzzing / short circuit. Help! A lex First Generation Faults & Fixes 1 Feb 15th, 2013 06:08 PM
Mini R50 Electrical remjoe General Discussion 1 Jul 6th, 2009 04:32 PM
