Newbie to the Mini. What the most reliable one to buy? - MINI Cooper Forum
Maintenance & MINI Care
 2Likes
  • 1 Post By minione2002
  • 1 Post By mike1967
post #1 of 3 (permalink) Old Jun 8th, 2018, 01:45 PM Thread Starter
Local Time: 10:37 AM
Quoted: 2 Post(s)
Hi all, I am new to this forum and seeking a new mini.
I'm not after the sporty version, I am after a regular diesel or petrol that I can get a lot of miles from. I tend to keep cars a long time. Current car a rover 75 has 220k miles on it. What version mini would I get similar without massive bills as I have read about timing chains and clutches failing etc?
Budget 10k
thanks again
Ian
peelaaa is offline
post #2 of 3 (permalink) Old Jun 8th, 2018, 04:54 PM
Moderator
minione2002's Avatar
Quoted: 625 Post(s)
If you're looking for a modern'ish mini then look no further than the 2007-2010 Mini Cooper D
These are fitted with the pretty Bombproof 1.6 HDI
They require a good thrash now and again to help with DPF regeneration
And timing belts require replacement every 100k.
After 2010 they switched to the n47 BMW diesel which is largely known for its timing chain stretching and failing.
Avoid all petrols from 2007-2010 if possible, if your heart is set on a Petrol try and go for a 2010+ LCI model with the N18 engine.
@mike1967 will be able to brief you on all the HDI's quirks.
mike1967 likes this.
minione2002 is offline
post #3 of 3 (permalink) Old Jun 8th, 2018, 05:41 PM
Quoted: 601 Post(s)
i just done my clubman cooper d on 90.000 miles new turbo, new dpf filter timing belt water pump etc, i use reconditioned turbo's from uk outlets under £200 and the dpf filter £112 timing belt water pump kit gates £79 just do all this every 75-100k and they are best option mine is one of the last psa diesel on later 2009-59 plate, my last one was mapped its was 58 plate sold it on 112k still got 4k for it and done all of the above,, 161 bhp at the wheels mainly mapped for economy was getting 50mph 80mpg on the flat around town late sixtys,
the later diesel bmw n47 is a total pug in my book what total idiot would mount a timing chain in such a way that engine out to replace it, and make it so it stretches like the petrol engines do, hmm pattern there, just thought i would answer matey via your mention bud
minione2002 likes this.
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
Best and Most reliable method to get to JCW poer levels on my 06 cooper S Paynts First Generation MINI Tuning 8 Dec 28th, 2008 10:11 PM
no! mini ranks the third last most reliable car yangwenli General Discussion 13 Jul 3rd, 2005 03:49 PM
the most expensive, most tricked out, most bestest mini.... Who owns it? andy_leitch First Generation MINI Cooper S 26 Mar 2nd, 2005 01:36 AM
Is CVT the most reliable MINI Willy First Generation CVT & Automatic 16 Nov 29th, 2004 07:29 PM
