2008 mini valves OEM number supply - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 8 (permalink) Old Apr 8th, 2019, 12:07 PM Thread Starter
Local Time: 07:28 AM
Quoted: 14 Post(s)
HI
I have taken my mini one 2008 engine N12B14A apart and need to find the right valves.
No idea of the OEM number for the parts?
And
Where to buy cheaply any help?
Mark
marksal is offline
post #2 of 8 (permalink) Old Apr 8th, 2019, 12:47 PM
Quoted: 691 Post(s)
head gasket
https://www.ebay.co.uk/itm/Head-Gask...72.m2749.l2649
inlet valve exhaust
https://www.ebay.co.uk/itm/Peugeot-M...72.m2749.l2649
for inlet valve contact the seller of exhaust valve for link to inlet valve
head bolts
https://www.ebay.co.uk/itm/Genuine-B...sAAOSwfRlbLKu6
this seller valves are very good quality rarely need to be lapped in
good tuners/repairs in southwest uk top guys 01579388980
good tuner/ecu body control clones etc lancaster up north uk DALE PHONE NUMBER 07807 222262 top guy.
mike1967 is offline
post #3 of 8 (permalink) Old Apr 9th, 2019, 08:16 AM Thread Starter
Quoted: 14 Post(s)
cheers Mike you diamond!
mark
marksal is offline
post #4 of 8 (permalink) Old Apr 9th, 2019, 12:54 PM
Quoted: 691 Post(s)
mark
one added thing i would if were you with head off do all the valve stem seals while its off i know its a pain but so many people on here have had stem seals fail
mike1967 is offline
post #5 of 8 (permalink) Old Apr 11th, 2019, 11:25 AM Thread Starter
Quoted: 14 Post(s)
Hi
Do you where I can buy new bolts for the ends of the camshaft?
see image
Any help would be great.
Mark
marksal is offline
post #6 of 8 (permalink) Old Apr 11th, 2019, 03:24 PM
Quoted: 691 Post(s)
Hi
see image
Mark
yep bmw do them think were £3.90 each last time i bought them, i've not found any after market ones,, i would also think about replacing the oil control seals in the end of camshafts first journals there is a upgraded set available i believe they have changed from metal to a carbon plastic type, these rings seal the camshaft oil feed to vanos sprockets, deffo worth doing while its a part
mike1967 is offline
post #7 of 8 (permalink) Old Apr 12th, 2019, 09:18 AM Thread Starter
Quoted: 14 Post(s)
Hi Mike,
Can you send me a web link to the bolts.
I am confused as to the type and OEM number, everyone keeps asking me for. cheer.
mark
marksal is offline
post #8 of 8 (permalink) Old Apr 12th, 2019, 10:35 AM
Quoted: 691 Post(s)
Hi Mike,
mark
there is no web link dealer only,, ocean bmw plymouth or any other bmw/mini main dealers. you will need reg number and chassis number to hand when ordering, also any Peugeot citroen dealers will have them for 1.3 or 1.6 vti engines of the 1.6 thp for turbo cars.
mike1967 is offline
2008 Clubman "Carbon on Valves"? andyleonard General Discussion 10 Dec 11th, 2011 09:40 PM
Blow Off Valves LiddleD First Generation MINI Tuning 46 Nov 15th, 2007 01:20 AM
Dump Valves The Elf General Discussion 1 Nov 25th, 2003 08:00 PM
Boost valves antnich First Generation MINI One 3 May 9th, 2003 11:01 AM
power boost valves? bigahead First Generation MINI Tuning 6 Aug 28th, 2002 10:12 AM
