Mini cooper 06 plate drivers window - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 1 (permalink) Old Apr 12th, 2019, 01:09 PM Thread Starter
Local Time: 11:39 AM
Hi I am looking for some advice my window has stopped working but not the normal common fault the motor still sounds when I click the switch but the window doesn't move. I can push and pull the window up and down manually also.
1. Could this be the cable has snapped and I just need a replacement cable set.
2. Replace all regulator minus the motor.
3. Tbe motor is sounding ok but cannot power the window and needs replacing.
Ben
Bphillips is offline
The swap from 02 plate ONE to 06 plate ONE supa-dupa-cooper General Discussion 1 Jun 6th, 2006 07:09 AM
National Mini Cooper Day at Beaulieu 11/06/06 Haggi UK & Ireland Discussion & Event Planning 21 Mar 7th, 2006 06:50 AM
