r56 valve cover hose - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 2 (permalink) Old May 4th, 2019, 06:47 PM Thread Starter
Local Time: 11:09 AM
Quoted: 5 Post(s)
The hose on the valve cover that connects to intake air duct I have noticed has no clip on it to secure it, will this have any affect on the running of the car.... Regards
Dom McNulty is offline
post #2 of 2 (permalink) Old May 4th, 2019, 07:14 PM
Quoted: 631 Post(s)
yes if ts leaving its part of pcv valve breather these were updated after 2010 with solid pipe ones before this they always crack and snap where you cannot see it involves removing the inlet manifold to access the bottom pipe fitting to remove and check them, the early ones barely last 5 years as plastic cracks from the heat,, new pipe is 29 from ocean bmw the last one i had, this pipe should be sealed, if you when can on idle remove the oil filler cap and it has not much effect on the running then chances are this pipe is at fault, but still worth checking anyway
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
Is this a heater hose, or radiator hose? Andryiakathlene Maintenance & MINI Care 2 Jun 26th, 2018 09:24 AM
Can I fix the valve cover pcv? air sound from valve cover and P1497 fault code Gabe3 Second Generation MINI Cooper S 4 Jun 8th, 2017 08:35 AM
Blowoff Valve/ Dump Valve on JCW? googoogaga Second Generation Works 2 Feb 2nd, 2009 05:35 PM
Leaking valve cover gasket LuckyRVA First Generation Faults & Fixes 2 Aug 29th, 2003 12:24 PM
Valve Cover Gasket Anyone? TonyB First Generation Faults & Fixes 2 Aug 13th, 2003 08:12 PM
