Diagnosing why rear squirter isn't squirting - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 5 (permalink) Old Jun 15th, 2019, 03:35 PM Thread Starter
Local Time: 03:45 PM
Quoted: 34 Post(s)
Hi,
2005 R53
My front windscreen squirter / washers work fine, but no water comes out of the rear one when I try.
I can hear the squirter motor running when I engage the steering column control for the rear window washer but no water emerges on the rear window and there doesn't seem to be water dripping anywhere when I fire-up the rear window-washer.
I've removed the rear wiper and checked the very final part of the pipework for blockages and there doesn't seem to be anything in the way so I'm a bit stuck what to try next.
Does anyone have any suggestions where I might investigate?
Thanks,
Steve
steveharman is offline
post #2 of 5 (permalink) Old Jun 15th, 2019, 05:09 PM
Local Time: 02:45 PM
Quoted: 9 Post(s)
Try a thin cable, like a bicycle gear or brake cable, down the washer jet.
It goes vertically through the motor & then 90degrees to the tubing to the front reservoir.
Otherwise, it's a blockage near the reservoir - a bit tricky to get to. Try some not-too-hot water or methylated spirits / alcohol.
Common problem, by the way.
Mike - MVPeters at comcast.net
2002 R53 MINI Cooper 'S'
MVPeters is offline
post #3 of 5 (permalink) Old Jun 16th, 2019, 07:28 AM
Quoted: 121 Post(s)
It’ll be the spindle blocked on the wiper motor.
k3fus is offline
post #4 of 5 (permalink) Old Jun 19th, 2019, 07:39 AM
Quoted: 1 Post(s)
Be careful.
That happened ti me on a Golf VI all boot was leacking and smell wett the conduit was broken.
Try to identify removing the boot door panels and fix the pipe if its broken.
Sent from my SM-A705FN using Tapatalk
martininach is offline
post #5 of 5 (permalink) Old Jun 19th, 2019, 08:57 AM
Stormbringer55's Avatar
Quoted: 24 Post(s)
Send a message via AIM to Stormbringer55 Send a message via MSN to Stormbringer55 Send a message via Yahoo to Stormbringer55
Check the pipe where it comes through the hatch back they can break.
Over Land and Sea.
Stormbringer55 is offline
