Clutch replacement and flywheel damage , need Help - MINI Cooper Forum
Maintenance & MINI Care
post #1 of 2 (permalink) Old Jun 16th, 2019, 09:09 PM Thread Starter
Local Time: 02:34 PM
Hello guys !
First off all, my english sucks. a lot.
well , im replacing a clutch in my mini one 1.6 90hp 2005, i already take out all the parts to make the exchange , im waiting for the components to arrive (massive oil licking from the crankshaft seal, thats for sure, if you think that could be more from another place , please tell me )
My major questions are :
-Can i reuse the bolts from the flywheel ? or im gonna have some issues , like braking nuts ?
- in my haynes manual they say you need to replace the bolts from the pressure plat ? what you guys think of that. because i cant find that bolts news , only preowned---
-i really donīt wanna by another flywheel. So , can i reuse mine ? (see the photos ) ?
she has a scratch , just can feel two with my nail, and i think you can see wich ones ...
ID:	228641   Click image for larger version
ID:	228643   Click image for larger version
ID:	228645   Click image for larger version
Nuno Dias is offline
post #2 of 2 (permalink) Old Jun 17th, 2019, 06:45 AM
Quoted: 682 Post(s)
looks to me that flywheel is damaged with heat craze, should always use new flywheel bolts as stretch bolts on crankshaft to flywheel, would also check the crankshaft for movement ie lever the flywheel when fixed to crankshaft check for excessive movement should not be able to feel more than twenty thou of a millimetre end float, if a more ten that is reason it is leaking oil and destroyed the seal.
good tuners/repairs in southwest uk top guys 01579388980
good tuner/ecu body control clones etc lancaster up north uk DALE PHONE NUMBER 07807 222262 top guy.
mike1967 is online now
