Water in the boot? - Page 3 - MINI Cooper Forum
MINI Clubman MINI Clubman 2007 - Present
post #31 of 32 (permalink) Old Jan 14th, 2014, 04:21 PM
Local Time: 12:54 AM
I have a 2002 Cooper S, I hear water running--especially seems to be side to side when I make a quick turn. I think it is inside the hatch door but the floor isn't wet. I'm afraid of rust! It only happens when there is heavy rain. Anyone else with this issue?
megrif56 is offline
post #32 of 32 (permalink) Old Jan 20th, 2014, 07:57 AM
Local Time: 09:54 AM
Slovenia
Originally Posted by mynameishenry View Post
Have had this problem, now solved I think.
I was getting litres of water in wheel well. No obvious signs of where it was coming in. I've stripped entire loadspace and diagnosed leak to gap between steel pressings.
If you open both rear doors, in front of you at the bottom of the door aperture, you have a plastic cover over the steel chassis pressing. Take off this cover, you have the door seal and exposed steel in front of you.
To the left and right, there is a join in the pressing to the inner wings housing rear lights.
The water was leaking between the gaps in this join - there is no seam sealer here so, if water finds it's way past the door seal from the top (which is does easily as the fit of the seal is poor) it will pool enough to pass the join and into the well.
Sealed with clear silicon, all good so far.
Hope this helps. Can send pictures if anything unclear.
Pictures would be great!
kokta is offline
Tags: ,
water in rear boot floor tool area jonjeffryes Second Generation Faults & Fixes 11 May 7th, 2015 04:17 PM
Water under driver's side carpet Hitman70 Second Generation Faults & Fixes 2 Sep 7th, 2013 03:06 PM
R57 Boot issues villiham General Discussion 2 Mar 28th, 2013 01:44 PM
09 cooper convertible boot lid problems Aysh Second Generation MINI Convertible 4 Dec 3rd, 2012 07:59 PM
mini convertible boot opening problems mase84 First Generation Faults & Fixes 0 Dec 3rd, 2012 06:20 PM
