rear door issues - MINI Cooper Forum
MINI Clubman MINI Clubman 2007 - Present
post #1 of 4 (permalink) Old Jan 10th, 2016, 11:54 PM Thread Starter
Local Time: 07:12 PM
rear door issues
Hi all, im in need of help. My 2010 clubman rear left door wont open and as i drive the rear doors open light comes on. Ive replaced the latch assy which works fine. Tested the new latch and door handles aginst the right door both work. Tested voltages on the handles. On the right handle the blue wire has 12v. On the left handle the blue wire has none. The wire colors change after the plug to brown and yellow like all the wires in the main harness and i dont know where it leads to to try and continue testing. Thanks for the help
Aaron Mabee is offline
post #2 of 4 (permalink) Old Jan 11th, 2016, 01:17 AM
Local Time: 08:12 PM
Quoted: 1037 Post(s)
I haven't had one apart yet considering I have 2 Clubmans but if the trigger assembly is like the switch on the R50 tailgate then I'd take the handle apart and give the contacts a good clean up
Sent from my SM-G920F using Tapatalk
SeanC is offline
post #3 of 4 (permalink) Old Sep 28th, 2016, 09:17 AM
Stormbringer
stormbringer's Avatar
Quoted: 1 Post(s)
On my 2008 only the right rear barn door opens on the remote .
Are the both supposed to open on the remote?
Waltham Forest College .Motor Vehicle Engineering Dept.
stormbringer is offline
post #4 of 4 (permalink) Old Sep 28th, 2016, 09:50 AM
No only the right hand door
SeanC is offline
Tags: , , , ,
Rear brake issue after changing ABS ECU/PUMP R50 Cooper hutch1975 First Generation Faults & Fixes 4 Feb 20th, 2015 06:35 AM
2014 Countryman SAll4 rear bumper removal marlinsfan MINI Countryman 3 Aug 2nd, 2014 11:50 AM
Rear Cargo Light - Turning it off while the back door is open Mario82288 General Discussion 2 May 12th, 2014 05:11 PM
MCS Clubman rear parking distance control juge Second Generation Faults & Fixes 1 Dec 14th, 2013 02:12 PM
