Check your sump for an oil leak - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 10 (permalink) Old Jun 28th, 2010, 07:53 PM Thread Starter
Local Time: 04:57 PM
Just had the Dooper in the dealers to rectify an oil leak.
Its a Sep 07 build; one of the first stop-start models, with 32K done. On collecting the car I asked what the problem was, and was informed that the sump and sump gasket had been renewed. (Plus on inspection it looks like the part that sits on top of the engine, where the oil filler goes into, has also been renewed.) On further enquiries they said they have had a few gaskets go, but no sumps.
Therefore it might be an idea for you all just to give your sump the once over, especially if you, like me, are close to the end of the warranty period; as it was only by chance that I saw a couple of oil drops on the garage floor.
No dramas getting it done though; dropped off in the morning, collected in the afternoon, all covered under warranty.
touche39414 is offline
post #2 of 10 (permalink) Old Jul 2nd, 2010, 09:00 AM
still learning
Local Time: 05:57 PM
Scotland Male
sounds like the oil filter gasket/seal has been leaking, perhaps not sealed/or damaged at the last service ?
they are probably making a large warranty claim on the sump/sump gasket which has not been leaking at all, and most likely not even changed !!
that's how they make their money.
Iain
iain cooper is offline
post #3 of 10 (permalink) Old Aug 26th, 2010, 09:18 PM
Stooey
United Kingdom Male View Stoo Med's White Silver & Black 2nd Gen MINI Cooper Diesel Clubman Profile View Stoo Med's Classified Ads
My '08 Clubbie Dooper had the sump gasket replaced at 24k last December. Car went in today for a 36k service and guess what... Another oil leak!!
Stoo Med is offline
post #4 of 10 (permalink) Old Sep 17th, 2010, 08:14 PM
Stooey
Had my 2nd sump gasket replacement last week and a rear main oil seal, so it was a gearbox out job. Thank heavens for a warranty. The cost to Mini was £741. Now p/x'ing it for a new one.
Stoo Med is offline
post #5 of 10 (permalink) Old Jan 5th, 2011, 03:45 PM
England Male
I've had 2 sump gaskets changed & now they tell me there's a leak that requires an oil pump change, plus more stuff is wrong on dismantling it, I'll see the full damage when I collect it in a couple of days. It's a 08 58 Cooper D with 63k on it, had it from new & everything has been done on time.
Aikon is offline
post #6 of 10 (permalink) Old Jan 6th, 2011, 01:45 PM
still learning
Scotland Male
this is ridiculous, why is it using so many sump gaskets/oil leaks ?
are they just ripping off BMW/MINI ? lucky it is still under warranty and I would get shot of it before the warranty runs out, or take out extended warranty.
Iain
post #7 of 10 (permalink) Old Jan 6th, 2011, 02:08 PM
England Male
You could be onto something, I have never complained about an oil leak, they've been "spotted" at services, it is still warrantied & on a TLC XL pack which should last til it goes back in 9 months with 80k on the clock (company car)
Aikon is offline
post #8 of 10 (permalink) Old Jan 7th, 2011, 03:11 PM
still learning
Scotland Male
if the car is under warranty and you have never had an oil leak you sure will when it comes to the service.
an easy way for the dealer to make money.
my landrover sat on the same spot on my driveway for nearly three years, but had an oil leak when it went in for the service, although my driveway was spotless !!
they had it in for four days and apparently changed gearbox seals !!..............problem is you never really argue if it's under warranty and the dealer knows that.
Iain
post #9 of 10 (permalink) Old Jan 12th, 2011, 09:16 PM
these are common
mine has had all above plus crank seal and is leaking oil onto the air con pump
friend has same fault
***** french crap
wes r56 is offline
post #10 of 10 (permalink) Old Mar 9th, 2011, 09:26 PM
Mejy Poo's Avatar
United Kingdom Female View Mejy Poo's Royal Grey & Black 2nd Gen MINI Cooper Diesel Countryman Profile
Sounds familiar
I have an 08 and had the oil leak corrected at approx 25k miles
Mejy Poo is offline
Tags: , ,
How to check for a crank seal oil leak mwuk First Generation Faults & Fixes 12 Jan 28th, 2017 10:26 AM
Oil Leak from Sump Gasket?? m17nuj First Generation Faults & Fixes 21 Oct 10th, 2012 07:40 PM
Last Service minor leak reported on sump johndover General Discussion 4 Aug 10th, 2009 06:50 PM
looking at buying a mini one has had a oil leak from the engine sump advice please!!! mini revs First Generation Faults & Fixes 4 May 26th, 2009 11:25 PM
Oil leak - sump and rocker cover gaskets... mini-kerm Maintenance & MINI Care 6 Dec 30th, 2008 04:13 PM
