Radiator Cooling fan - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 2 (permalink) Old Sep 24th, 2010, 02:39 PM Thread Starter
Local Time: 04:40 AM
Note of awareness to other Dooper owners.
My wife's Dooper was recently switching on the cooling fan very shortly after a cold start up, even though the bottom hose of the radiator was cold, indicating the thermostat had not even opened. I therefore assumed a potential sensor fault and took it into the dealer.
After an hours test diagnosis the dealer presented a report which detailed the amount of journeys the car had made and the duration in KM's. This pointed to the fact that the engine rarely got up to temperature so the emission control was performing a 'regeneration' by putting as much load electically on itself as possible to help clean the DPF. This is in conjuction with the on board fuel additive which is replaced every 100,000 miles in the service interval.
Diesel particulate filter - Wikipedia, the free encyclopedia
This would not of happened if the car was used on longer runs, as regeneration would of occurred during cruise.
In short its too complex and your are stuffed when it packs up later on.
Wardpaa is offline
post #2 of 2 (permalink) Old Sep 25th, 2010, 07:52 AM
Sorry, I don't really understand. Isn't the car doing what it's supposed to? Why will it pack up later on?
NeilT is offline
Radiator Cooling Fan is Broken dads_cooper Maintenance & MINI Care 1 Dec 8th, 2009 04:29 PM
Radiator cooling fan jammed on ? jones's mini First Generation Faults & Fixes 2 Jun 11th, 2009 01:12 AM
radiator cooling fan problem??? eddieboyII First Generation Faults & Fixes 3 Jul 1st, 2004 09:42 PM
Cooling Fan... foxtrotxray First Generation Faults & Fixes 4 May 26th, 2004 03:53 AM
Bleeding the radiator (air in cooling sytem) jmardy Maintenance & MINI Care 2 Jul 12th, 2002 12:26 PM
