Half power engine warning light - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 11 (permalink) Old Nov 1st, 2010, 12:46 PM Thread Starter
Local Time: 02:38 AM
Australia Female
Australia Half power engine warning light
I was driving on the Freeway today when an orange engine light came on, i pulled over to the emerg stop lane and looked up in my book what the signal meant. It said the engine was at half power and i could "limp home" but get engine checked out ASAP. Well just as i was about to turn my engine off, it just stopped. I waited for it to cool (thinking it may have been hot) and tried to start it again. It just shock like anything and cut out. Has anyone else experienced this problem?? Is it anything major? I had to get towed and it will get looked out tomorrow. Im just hoping it will be covered by warranty.Any help will be much appreciated.
NICHERS is offline
post #2 of 11 (permalink) Old Nov 1st, 2010, 07:11 PM
Local Time: 06:08 PM
Send a message via MSN to ScoobyChris
The engine warning light is a way of flagging up that a problem's occurred and if it's gone into limp-home mode, chances are the car thinks it's serious (at least in terms of potential damage) and is trying to preserve itself. Really need to get the OBD-II fault-codes read off the car's computer to pinpoint the exact problem, but with cars being as complicated as they are these days, it could be as simple as a sensor costing pence to replace that's the cause.
Pretty sure it should be covered by warranty....
Chris
ScoobyChris is offline
post #3 of 11 (permalink) Old Nov 1st, 2010, 10:27 PM Thread Starter
Australia Female
Thanks Chris.
I guess I'll find out soon enough. Fingers crossed it's nothing serious.
NICHERS is offline
post #4 of 11 (permalink) Old Nov 2nd, 2010, 02:24 PM Thread Starter
Australia Female
no news as yet. they havent even looked at it yet
NICHERS is offline
post #5 of 11 (permalink) Old Nov 2nd, 2010, 03:06 PM
That's annoying. On my current Fiat I had an intermittent problem whereby the fault code had cleared itself from the log by the time I got to the garage (I was lucky in that cycling the ignition cleared the light for my problem). In the end I bought my own OBD-II scanner off ebay for around £20 and read off the fault when it happened so I could tell them exactly what they needed to replace.
Will have to see if it's compatible with the MINI I have on order!
Chris
post #6 of 11 (permalink) Old Nov 4th, 2010, 12:11 AM
Local Time: 03:08 AM
Quoted: 1 Post(s)
Australia Male
Have you got a chip in it or gone over the service due date?
Will
OZmayfair is offline
post #7 of 11 (permalink) Old Nov 4th, 2010, 09:39 AM Thread Starter
Australia Female
It only went in for a service 2 months ago! It needs some part (so the dealer says) but i havent been able to get in contact with them (i work stupid hours). will finally cath them tomorrow to see what is going on
NICHERS is offline
post #8 of 11 (permalink) Old Nov 5th, 2010, 01:55 AM Thread Starter
Australia Female
The Mini garage said it was the high pressure fuel pump and also some damage to a belt or something. Apparently it happened when they stripped it (or something). Totally not mechanic at all!! It should be ready on monday and will be covered with warranty, thank goodness!!!
NICHERS is offline
post #9 of 11 (permalink) Old Nov 5th, 2010, 04:29 AM Thread Starter
Australia Female
I meant IM not that mechanic!
NICHERS is offline
post #10 of 11 (permalink) Old Nov 5th, 2010, 08:40 AM
Sounds like a good result, at least from a cost point of view! Bit worrying they damaged it when stripping it down but hopefully they're able to put it back together without breaking anything
Chris
post #11 of 11 (permalink) Old Nov 5th, 2010, 02:59 PM Thread Starter
Australia Female
Tell me about i, i was thinking the same thing!! I am now wondering what the hell they did to my car (two days before it did this) when they had it to change the tyre that blew!! Had some bad luck with my car of late!! Im a little over it! I cant believe its legal for a car not to carry a spare!! Stupid expensive run-flat tyres!! Hopefully smooth sailing from now on!
NICHERS is offline
Engine warning light & reduced engine power yellow peril Second Generation Faults & Fixes 31 Mar 6th, 2017 07:13 PM
HELP - Engine Warning Light fergusor Second Generation MINI Cooper S 7 Mar 15th, 2010 07:38 AM
Engine Warning Light coma First Generation Faults & Fixes 1 Feb 14th, 2008 07:27 PM
Engine Warning Light Jon007d First Generation MINI Cooper 5 Sep 15th, 2007 11:49 AM
engine warning light! nosaj First Generation Faults & Fixes 46 Apr 14th, 2005 04:21 AM
