Cooper D Nasty Engine Noise, Help!! - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 4 (permalink) Old Sep 24th, 2014, 06:24 PM Thread Starter
Local Time: 06:11 PM
Exclamation Cooper D Nasty Engine Noise, Help!!
I bought a 2007 Mini Cooper D a few weeks back and it has covered 75,000 miles.
A few days ago i noticed a weird sound (like the timing belt jumping or grinding against something) The belt doesn't seem to be sitting directly centrally on the 'wheel'.
Could the noise be the water pump?
I have very little idea about what this could be??
Has anyone got any suggestions about what this could be, it would be highly appreciated.
Will
William Dukes is offline
post #2 of 4 (permalink) Old Sep 25th, 2014, 08:06 AM
Quoted: 1 Post(s)
Luxembourg Male
My belt doesn't sit centred either. I think this is a "feature" of the car rather than a problem. The water pump failing makes more of a screeching/whistling/high-pitched noise at idle rather than a grinding noise.
Is this car a manual transmission? IF so, then one possible source of the noise could be the throwout bearing in the clutch housing and/or the dual-mass flywheel that could need replacing (especially at that mileage if the car was driven rough by the previous owner).
Can you try to localize the noise and/or perhaps see if it is transmission related? Does it occur all the time? When the car is moving? When the car is stationary? Both?
Will
MiniDeLux is offline
post #3 of 4 (permalink) Old Mar 13th, 2015, 01:23 AM
Local Time: 05:11 PM
Exclamation Smoke from Cooper D engine noise
Hi,
not sure if this is the right place am new sorry if its in the wrong place.
Im from England..
I have a mini cooper D 2007 which hasnt given me any problems at all...well so I thought....it just failed its MOT!!!
the reason for Failure was according to Kwik-fit "Engine sounds poor condition and emits black smoke on acceleration."
I have no idea what it could be I contacted Local mini but was unable to get much help apart from the usual book it in which I have done....I thought in the meantime maybe someone else can help??
Thanks!!
AC15 is offline
post #4 of 4 (permalink) Old Mar 15th, 2015, 04:56 PM
Quoted: 1 Post(s)
Luxembourg Male
Probably EGR - related. Need to get a diagnostic done.
"Engine sounds poor condition" sounds pretty subjective to me...
Tags: , , ,
Engine noise Leedz Second Generation MINI One 1 Oct 26th, 2014 02:40 PM
2003 mini cooper s engine ticking noise when idling. tlw3333 Welcome New Members 2 Feb 14th, 2014 02:09 PM
2005 Cooper S Squealing Noise Independent of Engine Speed uilleann-piper First Generation MINI Cooper S 1 Sep 24th, 2013 09:18 PM
Oil consumption Mini Cooper s N18 engine peterhellawell Maintenance & MINI Care 1 Jan 24th, 2013 09:11 PM
