2008 cooper D DPF warning light - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
Old May 27th, 2015, 06:28 PM Thread Starter
Local Time: 01:33 AM
United Kingdom View tcyjohnny's Classified Ads
Question 2008 cooper D DPF warning light
Today I turned off the motorway and this DPF warning light came on. I drive 40 miles of motorway miles a day so surely it can't be blocked? Car has now done 75k.
Am I having to save up a 4 figure sum to be ready for the dealer's "The DPF unit needs to be replaced at £850+" talk??? I am fearing the worst!!!
tcyjohnny is offline
Old May 27th, 2015, 06:45 PM
Local Time: 12:33 AM
Quoted: 6 Post(s)
Garage
Try looking for a garage that can remove the DPF and remap the software to ignore it. Lots cheaper.
http://dpfdeletion.com/
Peteren69 is offline
Old May 27th, 2015, 06:46 PM
Quoted: 40 Post(s)
If it is a diesel of Peugeot origin (pre-2011-ish?), it could be that the EOLYS fluid has run out. This is an additive that is pumped into the DPF to make it work. The 'tank' is not refillable and is more like a bladder - a new (full) one is fitted.
Angib is offline
Old May 28th, 2015, 05:52 AM Thread Starter
Thank you. I believe my Dooper is of Peugeot origin (w12 engine code I believe), I will drop the car into a garage near work to check out the eolys additive top up/replacement bladder.
Old May 28th, 2015, 04:16 PM
I had the same problem. It wasn't the DPF this time. It was the EGR valve that was sticking and sadly the "EOLYS" fluid was also empty. It was just over £500 in total at the Dealer in Lincoln. The EGR fault caused a bit of rough running and occasional loss of power. As for the additive fluid - I didn't leave it too long after the light came on as the regeneration won't work. With no regeneration you will need a new DPF if you leave long enough!!
Dont go for the DPF delete option, as some companies proudly offer this service which is just about to be (or very soon) a legal MOT requirement. If it was fitted at the factory then it will still need to be present. A quick google of this will satisfy your curiosity.
Scorpius is offline
Old Jun 6th, 2015, 07:51 PM Thread Starter
Thank you all, it turned out to be a faulty glow plug and its error code stopping the DPF regen (apparently).
All is well now after a new glow plug and a new eolys bag refill.
Hope it helps someone who finds this post in the future.
Old Jul 4th, 2015, 05:36 PM
Quoted: 4 Post(s)
Scotland Male View mitchgixer6's White Silver & White 2nd Gen MINI Cooper Diesel Profile
Just out of interest how much was it for the new fluid?
mitchgixer6 is offline
Tags: , ,
MINI Cooper S vs Fiat 500c Abarth AG Jeff MINI News 23 Dec 20th, 2017 09:18 AM
DPF light but no fault codes DJ-R56 MINI Cooper Diesel 2 Aug 22nd, 2015 12:55 PM
Need your help please! Low tyre pressure warning light - RED C00P3R2011 First Generation Faults & Fixes 0 Feb 1st, 2015 03:53 PM
DPF warning light (only for a second) NightfireCooper MINI Cooper Diesel 1 Feb 5th, 2014 09:59 AM
Battery warning light, overheating warning light LizzyG Second Generation Faults & Fixes 2 Jan 2nd, 2014 05:30 PM
