Starting problems - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 3 (permalink) Old Apr 23rd, 2016, 09:38 AM Thread Starter
Local Time: 03:00 AM
Female
Starting problems
Hello everyone,
I have Mini Cooper 1.6 Diesel (2007 R56) and I have a problem with it. It doesn't want to start engine sometimes but it cranks every time. When we finally manage to start it everything works fine and there are no errors or warning information.
That started happening after great service when we changed fuel filter. So logically we thought that problem was in it and we changed it again, but the same story repeated. Then we put transparent hoses and we saw that after some driving air appeared in fuel system. Again we changed some hoses, connections on them, crankshaft sensor, put some irreversible valves etc. but nothing changed. We talked with few mechanics and they think that problem is somewhere in those hoses and suggested us to change all that system. Btw I think that it is impossible to buy just a part of them it is necessary to buy whole system.
Did anyone have the similar problem? Do you have any ideas what to try/do? We heard that this air issue is usual thing on Peugeot 1.6 engines. One mechanic suggest us to do overhaul of pump and injectors but everything worked fine before that great service.
Maybe I should mention that this engine model doesn't have fuel pump. We were also thinking to embed it, but we concluded that it would be really ugly solution.
Thank you in advance.
Regards,
Sanja
Sanjitza is offline
post #2 of 3 (permalink) Old Apr 23rd, 2016, 10:11 AM
Quoted: 1037 Post(s)
Haven't you already got this thread running elsewhere on the board?
SeanC is offline
post #3 of 3 (permalink) Old Apr 23rd, 2016, 10:28 AM
Zuke's Avatar
Local Time: 04:00 AM
Quoted: 35 Post(s)
Ukraine Male
Garage
Why do this, it just wastes the time of people who might have helped you.
https://www.mini2.com/forum/second-ge...-problems.html
Zuke is offline
Starting problems CastIronDuke Second Generation Faults & Fixes 11 Apr 22nd, 2016 09:57 AM
Intermittent Starting Problems naughtyneck Second Generation MINI One 2 Mar 29th, 2016 09:03 AM
Starting Problems wolf242 First Generation MINI One 1 Dec 16th, 2015 11:00 PM
Problems starting the engine after ran out of fuel beaver25 General Discussion 1 Jan 12th, 2015 03:56 PM
mini r50 starting problems Option69 First Generation Faults & Fixes 1 Aug 3rd, 2014 04:51 PM
