MINI Cooper R56 (2008) D1.6 Intermittent Acceleration - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 4 (permalink) Old Feb 4th, 2017, 07:47 PM Thread Starter
Local Time: 05:22 PM
Hi there once again guys. I received back my car from a serious leakage that was discovered after a month of investigation. The problem was a faulty injector seal and it has been replaced. After repairing the car, the next day while accelerating from low rpm and second gear the car has an intermittent of acceleration. Not too serious though, you can just feel it.
The problem is that it doesn't happen often, just every now and then. I used to have this problem when I had petrol engine cars and usually was coming from faulty sparks. Since my car is diesel I don't know from where is it coming from.
Does anybody know what can cause an intermittent acceleration on a diesel engine?
panpatrinos is offline
post #2 of 4 (permalink) Old Feb 4th, 2017, 08:56 PM
Quoted: 1037 Post(s)
Dirty/ clogged injectors, worn injector seal/s, dirty fuel filter, worn HPFP, dirty/ faulty EGR Valve or quite possibly something else.
I'd whack a bottle of wynns injector cleaner in it with the next couple or 3 tank fulls first and see if that makes any difference. When was it's last oil service (including air filter) ?
SeanC is offline
post #3 of 4 (permalink) Old Feb 4th, 2017, 08:59 PM
Oh try BP Ultimate too if you don't already use it. Keep away from the supermarket shyte. BP Ultimate has a cleaning agent in it
SeanC is offline
post #4 of 4 (permalink) Old Feb 4th, 2017, 09:15 PM Thread Starter
Hi SeanC. Thanks for your help again. Technically the seals are brand new. In fact one of them was causing the leaking in previous conversations we had. After the replacement of the seal the problem appeared.
I will use this injector cleaner for a start and see how it goes. I will let the garage know immediately since it has been a day away from them. It looks like I fix one problem and another one appears.
Tags: , , ,
The G_P Roof Number List AprilWhine First Generation Works 1311 Jan 13th, 2018 06:02 PM
CVT Transmission Failure slaybalj First Generation CVT & Automatic 144 Jan 3rd, 2018 10:22 PM
Hello and questions from a possible new Mini Cooper R56 Owner Jonny5H Welcome New Members 16 Mar 10th, 2016 10:17 PM
2015 MINI Cooper Hardtop Review AG Jeff MINI News 0 Jan 8th, 2015 03:30 PM
URGENT - HELP/ADVICE NEEDED FOR R56 Mini Cooper S 2007 LadyUK Second Generation MINI Cooper S 18 Oct 23rd, 2012 06:29 PM
