Diesel leaking - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 3 (permalink) Old May 30th, 2017, 07:51 AM Thread Starter
Local Time: 08:41 PM
Quoted: 3 Post(s)
Diesel leaking
Got a small leak of diesel that is dripping from the back of the right-hand-side under-guard plastic panel. Seems to be coming from under the driver's seat area.
Before I get it taken to my local garage - anyone got any ideas please? Or had a similar problem
Car drives fine and no warning lights.
Jonathan Harding is offline
post #2 of 3 (permalink) Old May 30th, 2017, 12:42 PM
Quoted: 1037 Post(s)
If it's leaking from under the car then it's likely to be the fuel line
Sent from my SM-J510FN using Tapatalk
SeanC is offline
post #3 of 3 (permalink) Old May 31st, 2017, 08:13 PM
Quoted: 652 Post(s)
the have fuel lines one suply other a return pipe, supply line goes to the passengers side rear of engine ie square black filter these have a knack of leaking where the pipe joins the filter as this point has a slide in part to rear of filter, iff leakes here they allow fuel to run down the pipe and look like leaking from under the floor,, unless someone has hit the pipes that run under the car,, the return pipe goes from the high pressure fuel pump drivers side rear of engine right hand drive
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
some really good advise for 1.6 hdi diesel mini owners mike1967 Maintenance & MINI Care 7 May 3rd, 2019 10:40 PM
N47 diesel fuel filter Minifixer Maintenance & MINI Care 0 Apr 18th, 2016 03:27 PM
Decisions on new 3 door MINI Cooper Diesel Oily Puddles General Discussion 3 May 2nd, 2015 10:54 AM
New Engine Mount Leaking MiniMichelle1989 First Generation Faults & Fixes 1 Nov 11th, 2014 05:38 PM
considering buying my first cooper diesel, many many questions! jk003 General Discussion 6 Apr 3rd, 2014 06:29 PM
