Oil Catch Can - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
 1Likes
  • 1 Post By AstroCooperS
Old Aug 19th, 2017, 09:21 AM Thread Starter
Local Time: 02:09 AM
Quoted: 2 Post(s)
Australia Male
New Zealand Oil Catch Can
Is there anyone on this forum that has had experience with fitting an oil catch can on Cooper D R56 W16 Engine?
bugga is offline
Old Aug 19th, 2017, 09:43 AM
Moderator
minione2002's Avatar
Quoted: 625 Post(s)
why does it need a catch can?
minione2002 is offline
Old Aug 19th, 2017, 09:10 PM
AstroCooperS's Avatar
Quoted: 27 Post(s)
England Male
I normally put cardboard on the floor under the front of the car,
its easy to get rid of after...
SeanC likes this.
AstroCooperS is offline
Old Aug 19th, 2017, 11:22 PM
Quoted: 1037 Post(s)
Lol
Sent from my SM-J510FN using Tapatalk
SeanC is offline
Old Aug 21st, 2017, 02:06 PM Thread Starter
Quoted: 2 Post(s)
Australia Male
AstroCooperS. The question is serious and important. Pull the pipe from the airbox off your turbo and have a look at the blow-by oil. And there is nothing "" about it SeanC :-(
bugga is offline
Old Aug 21st, 2017, 02:11 PM Thread Starter
Quoted: 2 Post(s)
Australia Male
AstroCooperS. The "Blow-By" oil and fumes that gets past the piston rings does not fall to the floor onto cardboard! It leaves the PCV unit and enters your turbo to reticulate through your system. Read and Learn.
bugga is offline
Old Aug 21st, 2017, 02:17 PM Thread Starter
Quoted: 2 Post(s)
Australia Male
Minione2002. The oil catch can is to capture the oil and fumes that get past your piston rings, flow through the PCV (Positive Crankcase Ventilation) and then through your turbo causing undue damage.
bugga is offline
Old Aug 21st, 2017, 02:24 PM Thread Starter
Quoted: 2 Post(s)
Australia Male
Here's a Quote from Pelican Parts;
The R56 MINI Cooper S is prone to excessive oil vapor within the intake system from the crankcase breather system. This can cause a build up of oil residue on the intake valves as well as moisture and oil in the intake air ducts.
A catch can separates the oil vapors from the crankcase air before it is returned back into the intake system, keeping your intercooler and sensors working at peak performance. If you've ever taken off your intercooler, you most likely noticed a build up of oil within each rubber boot sealing each end of the intercooler. Spray some cleaner into it and you'll quickly discover massive amounts of oil that build up inside the intercooler. This oil coating is not in itself harmful to the general operation of the engine, but it does affect the performance by limiting the efficiency of the intercooler in cooling the compressed intake charge, not to mention gumming up various sensors and components including the critical intake valves.
bugga is offline
Old Aug 21st, 2017, 03:20 PM
Quoted: 10 Post(s)
Garage
This is a problem for the direct injection petrol engines such as the Cooper S in your quote, not the diesels.
2008 R55 MCS Clubbie
2003 R53 MCS Hatch
freck99 is offline
The Following 2 Users Say Thank You to freck99 For This Useful Post:
Old Aug 21st, 2017, 04:37 PM
@bugga yer awfy sensitive man. Chill out
Fit an oil catch can then report back with your findings rather than be over sensitive about what we're saying. Just for your information, I currently run 2 Cooper D's and one is on 139,000, that's 223698 in Australian gold coins and I have previously ran Peugeot's with the Hdi engines well in excess of 270,000 miles which is nearly half a million km's and never felt the need to fit an oil catch can, nor have I noticed any loss of performance or oil contamination in the turbo or anywhere else for that matter but having said that all my cars are serviced every 6000 miles and I'd consider them better than average on mechanical health
SeanC is offline
Old Aug 22nd, 2017, 01:04 PM
Moderator
Quoted: 625 Post(s)
Hmm live and learn..
never new "fumes" could damage a turbo.
Old Aug 23rd, 2017, 08:02 PM
Quoted: 652 Post(s)
the issue with oil tank vented out side of the intake is crankcase gases have high nox gases thats the worst of it and mot failure on top of breathing in those gases while driving along the road is not a good outcome, i've stopped doing this method as it causes other issues depending on what car. ie sensors get clogged up from egr soot on diesels, the petrol vti engines suffer from valves getting clogged more,, a closed oil tank with a pipe that collapses when under neg vacum is best method so system still sealed to the intake and not a failure it just removes the oil
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
Oil catch can kit dad Second Generation MINI Tuning 6 Apr 8th, 2017 01:07 AM
choosing & installing the oil catch can genik Second Generation MINI Cooper S 2 Jul 26th, 2015 04:55 PM
Red oil lamp light went off a day after oil change erinminilover Maintenance & MINI Care 1 Jan 16th, 2015 09:37 AM
Low Oil Pressure - Filter Debris in Oil System??!! MissMac General Discussion 5 Apr 1st, 2013 10:23 AM
R52/R53 best oil catch can for 2012? joylove First Generation MINI Cooper S 0 Dec 7th, 2012 05:17 PM
