Mini Cooper 1.6 D ~ No Turbo Boost Please Help ! - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 4 (permalink) Old Oct 4th, 2017, 10:12 PM Thread Starter
B218ahb1's Avatar
Local Time: 01:43 PM
Quoted: 2 Post(s)
Hello everybody! I would really appreciate your help. I have a R55 mini Clubman Diesel with 122,000 on the clock. Injector 3 was leaking massively so I changed all the copper seals on all 4 injectors. Now I have no turbo boost at all. It starts and runs perfectly with no smoke at all. I fitted a new vacuum solenoid, blanked off the egr valve and still no boost. Changed the turbo, cleaned the pick up, cleaned the oil cooler, intercooler etc but still no turbo! Can anyone shed some light on the situation before I go out of my mind 😩
B218ahb1 is offline
post #2 of 4 (permalink) Old Oct 5th, 2017, 06:49 AM
Quoted: 663 Post(s)
first off diagnostic scan is a must to find it fast,, but couple of clues for me would be the small vac pipes that run the vnt on the turbo you said you replaced the solenoid valve check the pipes are on the correct way around, bearing in mind one pipe is just a breather for the diagram inside the valve also would check the map sensor wiring or sensor not got gummed up when cleaned out the pipe work,, also if you have blanked off the egr valve with removing the software for it then car will go in to limp mode... you can not just blank off a egr valve on those engines ,,, that said you can restrict it by having a 7mm hole drilled in middle of it,,, those engine because of dpf must have no fault codes stored in ecu to allow the dpf filter to regenerate.... i have 2008 clubman cooper d with egr and dpf delete and a map its first engine went bang due to glowplugs not working this caused the dpf to block up and still last owner drove on until finally the turbo went south and went in to a diesel run on ie drank its engine oil and reved until had holes in cylinder block from conrods out the side, i have seen seen a lot of these on all makes of modern cars over the years,,,
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
post #3 of 4 (permalink) Old Oct 5th, 2017, 07:08 AM Thread Starter
B218ahb1's Avatar
Quoted: 2 Post(s)
Thanks mike, will check the vac hoses are on correctly... any idea on which way they go? Have done a code scan and the only code is an alternator code which won’t clear! It is a brand new alternator. Is there a way to tell if this is a dpf fault?
B218ahb1 is offline
post #4 of 4 (permalink) Old Oct 5th, 2017, 08:58 AM
Quoted: 663 Post(s)
what are you using to scan it, because P-codes will not show up on most scanners, inpa or autocom cdp plus or snap on or launch pro ie dealer level,,
autocom on ebay £57 one is best its user friendly cant do any damage with it and will allow full function for all systems, including dpf, get one go in to live data you can add streams to it off a list add all dpf and fueling streams you will be looking for particulate filter last regen, also looking for particulate filter content if this shows more than 75% its time to change or delete also the soot content,, you can try a forced regen but this wont work if car has any fault codes saved in memory and to be honest on 75% filter and new turbo its a gamble could kill your new turbo, as regen is 8-12 minutes car will rev by its self at 4000 revs and boy it gets hot,, always have bonnet up dont walk away from it keep watching for any issues under the bonnet also pays to put car on a concrete standing as exhaust gets so hot...
as for the vac controller the pipe nearest the multi plug for electric side of it is the vent pipe should have a filter on it. the next pipe in ie the middle connection is feed from the vac pump supply and the end one is the feed to turbo,, thats how mine is and mine works fine..
The G_P Roof Number List AprilWhine First Generation Works 1311 Jan 13th, 2018 06:02 PM
MINI Cooper S vs Fiat 500c Abarth AG Jeff MINI News 23 Dec 20th, 2017 09:18 AM
Mini cooper 2008 s - turbo issue mohdghattas Second Generation MINI Cooper S 1 Sep 7th, 2014 11:48 AM
Mini HQ - Terrible ethics for the customer. jobforacowgirl Dealership Feedback 11 May 22nd, 2014 05:36 AM
06 Mini Cooper S Turbo no boost? Mini4Life06 Second Generation Faults & Fixes 1 Jan 28th, 2014 04:31 PM
