Mini Cooper SD - Knocking Sound from Engine. - MINI Cooper Forum
MINI Cooper Diesel MINI Cooper Diesel 2007 - Present
post #1 of 2 (permalink) Old Jan 20th, 2019, 07:25 PM Thread Starter
Local Time: 07:42 AM
Quoted: 1 Post(s)
United-Kingdom Mini Cooper SD - Knocking Sound from Engine.
I have a 2011 Mini Cooper SD. Since the temperature outside has dropped and we are having cold mornings, I have noticed a knocking noise recently when I first start the car. I can hear the noise when the clutch pedal is on the floor, and the noise disappears when I take my foot off the clutch. When the engine is warmed up the knocking noise seems to go completely. I would be interested to know if anyone else with a Cooper SD has experienced the same thing please ? Not sure if it indicates a problem or this noise is normal. Any advice would be greatly appreciated please. Many thanks.
Brizzle1965 is offline
post #2 of 2 (permalink) Old Jan 21st, 2019, 12:33 PM
Quoted: 630 Post(s)
mixture of cold air temp cold fuel temp and when a diesel first starts as its a compression ignition engine the ecu starts at retarded timing with extra fuel at start up and the cold air is more dense the ignition sound sharper
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
Help! Knocking sound from engine, local expert needed. NE UK StandardN3rd Second Generation MINI Cooper S 5 Feb 8th, 2016 05:31 PM
Mini Cooper R53 knocking/ticking sound benmandv First Generation MINI Cooper S 2 May 2nd, 2015 09:26 AM
2004 Cooper S Engine knocking sound TommMM First Generation MINI Cooper S 3 Mar 30th, 2012 06:18 PM
engine knocking sound patsf1 First Generation Faults & Fixes 3 Apr 7th, 2009 05:58 PM
what does engine knocking sound like? mini vanilli First Generation Faults & Fixes 10 Aug 22nd, 2005 12:26 PM
