No low down power - MINI Cooper Forum
MINI Cooper S Diesel MINI Cooper S Diesel 2011 - Present
post #1 of 2 (permalink) Old Aug 1st, 2016, 12:23 PM Thread Starter
Local Time: 08:37 AM
Quoted: 1 Post(s)
Question No low down power
Advice needed please.
I bought my 2011 SD convertible with only 21,000 miles back in March this year. It has full Mini service history.
I've covered 4,000 miles since and love the car.
On a few occasions I've notice that the engine tone is deeper than normal, almost like in a petrol car when you try to accelerate in too high a gear. The other thing that happens is when I turn the engine off after the tone is deeper is that the cooling fan comes on and stays on for between 5 and 10 minutes.
Yesterday on a 120 mile motorway journey, I again noticed the engine tone was deeper and low down power seemed to be less than normal, instead of being happy at around 1,800 revs it felt as if I needed to change down a gear.
When I got to the car park, it wouldn't pull at all below 1,500 to 2,000 revs.
No warning lights came on.
After parking and returning to the car and hour later, it started without issue and was fine all the back for the 120 miles.
Any idea what could be wrong ???
David
SD Cab is offline
post #2 of 2 (permalink) Old Aug 10th, 2016, 02:57 PM Thread Starter
Quoted: 1 Post(s)
All sorted now
I took the Mini to Warne Motors in Bury St Edmunds, Suffolk, which is my local independent BMW and Mini specialist.
The car had recorded fault codes relating to exhaust pressure and a couple of other problems which indicated that the routine self-cleaning of the EGR wasn't being completed correctly.
The fault codes were cleared and the cleaning cycle initiated and I drove the car along the A14 at 65 - 70 mph to Ipswich and back.
Returning to Warne Motors, it was again plugged in and the cleaning cycle had completed successfully and no faulty codes were logged.
Car feels as it should so for 45 I'm very pleased and relieved.
SD Cab is offline
Tags: , ,
2003 Cooper S Power Steering Fix and subsequent dealer issues puttinginwork First Generation MINI Cooper S 6 May 5th, 2016 07:03 PM
Power not stable, kept losing power, broke down 4 times in the last month clammy77 First Generation MINI Cooper S 1 Apr 2nd, 2016 01:59 AM
Has any one been able to save their power steering pump after it had shut down? Jimmy Jamblez First Generation Faults & Fixes 6 Feb 25th, 2016 10:55 PM
02 jcw low power output bloomers77 First Generation MINI Tuning 0 Mar 21st, 2015 12:45 AM
Power Steering Rack & Pinion Frustration VerticalMinded First Generation MINI Suspension 4 Jan 28th, 2014 08:14 PM
