Exhaust smell at start up - MINI Cooper Forum
MINI Cooper S Diesel MINI Cooper S Diesel 2011 - Present
 2Likes
  • 1 Post By Cailbrin
  • 1 Post By SeanC
post #1 of 10 (permalink) Old Apr 1st, 2017, 09:10 AM Thread Starter
Cailbrin
Local Time: 11:03 PM
Quoted: 1 Post(s)
Male
Morning
We have just bought a 12 plate 2.0 SD Countryman
Lovely car, but on start up (first thing) the cabin stinks of exhaust fumes.
I have been trying to pair my Wife's phone to the car and had to open the windows to try and get the smell out of the car.
It seems to be fine when you are driving, we did about 40 miles yesterday and the smell soon goes away.
Has anyone else had similar issues ?
Cailbrin is offline
post #2 of 10 (permalink) Old Apr 1st, 2017, 09:37 AM
Local Time: 09:03 AM
Quoted: 292 Post(s)
Australia Male
Garage
If you can smell exhaust smoke then you have a leak, don't forget that carbon monoxide is odourless so even with the windows open you may be gassing yourself. Have the car looked at and find out where its leaking from before the unthinkable happens.
Milpol is offline
post #3 of 10 (permalink) Old Apr 1st, 2017, 01:39 PM Thread Starter
Cailbrin
Quoted: 1 Post(s)
Male
Tried the engine again this afternoon, and it stinks.
Popped the bonnet and you can smell it in the engine bay.
It is going back to the garage next week.
Hopefully it will get fettled asap.
Milpol likes this.
Cailbrin is offline
post #4 of 10 (permalink) Old Apr 2nd, 2017, 12:25 AM
Quoted: 292 Post(s)
Australia Male
Garage
Better safe than sorry Cailbrin and hopefully its a quick and easy fix.
Milpol is offline
post #5 of 10 (permalink) Old Apr 2nd, 2017, 12:59 AM
Local Time: 12:03 AM
Quoted: 1037 Post(s)
Is there any obvious soot in and around the engine bay? It may be worth starting the car with the bonnet open and as soon as it starts then inspect the engine bay for any obvious smoke. That way you may find where the leak is. Also stick your head under the car to see if it's leaking from the exhaust pipe.
Milpol likes this.
SeanC is offline
post #6 of 10 (permalink) Old Apr 2nd, 2017, 01:59 AM
Akkip's Avatar
Quoted: 16 Post(s)
Norway Male
As innocent as an exhaust leak may sound, it is something that should be taken seriously, especially if you can smell it in the cabin.
The culprit is as stated above here a leak somewhere, and you need to find it and have it fixed, until then i suggest you limit the use of the car to the necessities as carbon monoxide is rather uhm "unhealthy".
Akkip is offline
post #7 of 10 (permalink) Old Apr 2nd, 2017, 10:06 AM Thread Starter
Cailbrin
Quoted: 1 Post(s)
Male
Thanks for the idea.
My son watched the engine bay while I started the engine and there was a plume of smoke from the silver cylinder at the top of the picture - can you tell I am a numptie when it comes to mechanical things ?
Can you someone gently tell me what the silver cylinder is ?
Cheers,
Cailbrin is offline
post #8 of 10 (permalink) Old Apr 2nd, 2017, 10:38 AM
Akkip's Avatar
Quoted: 16 Post(s)
Norway Male
Cheers,
That would be your exhaust manifold and turbo combo, the silver sheet is just a heat shield to protect other components from the heat coming off the turbo.
The little cylinder with a lead attached to it is probably an EGT (Exhaust Gas Temperature) Sensor.
Akkip is offline
post #9 of 10 (permalink) Old Apr 2nd, 2017, 10:53 AM
As Akkip has pointed out the silver thing is the heatshield so if the leak is coming from under here then you will need to remove it (usually a few 10mm bolts) and have a closer look. If the smoke is coming from the plug then a simple tighten may fix it. If you get the heatshield off then if you take a piece of tissue (bog roll) and hold it over the joints then it should flap about when it senses gases. This saves you from putting your face near the exhaust gases and breathing them in
SeanC is offline
post #10 of 10 (permalink) Old Apr 2nd, 2017, 11:02 AM Thread Starter
Cailbrin
Quoted: 1 Post(s)
Male
Thanks for the replies.
We have only had the car for 3 days, it is going back to the garage and they can fettle it.
Cailbrin is offline
aFe Mach Force XP 304 SS Cat-Back Exhaust System for your Mini! CARiD CARiD.com 0 Jan 5th, 2017 11:34 AM
Borla exhaust systems for Mini Cooper CARiD CARiD.com 2 Feb 5th, 2016 04:08 PM
2010 Cooper S crank but wont start when its cold regretfulminiowner Second Generation Faults & Fixes 10 Jan 21st, 2016 11:29 PM
ADVICE:repair exhaust or get JCW?! Newtonn General Discussion 1 Jun 8th, 2013 11:38 AM
Burn smell from new exhaust Mugello First Generation MINI Cooper 4 Jan 12th, 2013 06:07 PM
