Mini One Battery Drain: 2011 year - MINI Cooper Forum
post #1 of 3 (permalink) Old May 13th, 2019, 02:16 PM Thread Starter
Local Time: 06:24 PM
Quoted: 1 Post(s)
United-Kingdom Mini One Battery Drain: 2011 year
BMW tells me our Mini One is waking itself up regularly and causing a continuous battery drain, but requires another three hours of very expensive diagnostics to pin down the problem, and even then they cannot guarantee they will find the problem.
The car is dated 2011.
After replacing the battery, we disconnected the battery when the car is not being unused, and now the dashboard shows the ABS light in yellow.
Does anyone have any ideas?
We're trying to find a fix without spending a fortune with BMW.
Rich Tolcher is offline
post #2 of 3 (permalink) Old May 14th, 2019, 09:58 AM
knt
Quoted: 34 Post(s)
How long has the car been like that?
Have you added/removed anything from the car's electrical system?
What was the last thing done to the car before the battery drain?
If the ABS or anything triggering it is not faulty then clearing the code should do it.
knt is online now
post #3 of 3 (permalink) Old May 14th, 2019, 02:34 PM
Quoted: 629 Post(s)
first job would be work out which circuit is waking the bcm up from sleep, below link a must have tool for this, you can plug in to the fuses one at a time let car sleep then see if that circuit has a amp drain on it and how much, 250ma is normal but anything above 500ma ie half a amp is not,
https://www.ebay.co.uk/itm/Blade-Fus....c100005.m1851
the abs light should switch off after car as moved about 100 yards as takes that long for abs and ecu to talk and work out its all moving as such,
you changed the battery did you have it encoded also by leaving ot unplugged it will lose the code and need resetting again this can bring car off sleep as ecu will be searching for the very power it needs to be set as such,,
you would be better off buying a solar panel leave it on dash connected to battery when not being used rather than disconnect, also devil advocate if car got stolen with battery off it not protected by its alarm etc they wont pay out,
link below for solar panel good value,
https://www.ebay.co.uk/itm/10W-12V-C...b086735a0c1d13
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
2003 Mini One - Parasitic Battery Drain pyrotekky First Generation Faults & Fixes 6 Sep 18th, 2018 07:43 AM
Mini Cooper S 2003: Battery drain jmb Maintenance & MINI Care 30 Jun 21st, 2012 03:47 PM
