2007 Mini Cooper D limp mode with no EML - MINI Cooper Forum
post #1 of 10 (permalink) Old Jun 24th, 2019, 01:16 PM Thread Starter
Local Time: 12:41 AM
Quoted: 2 Post(s)
Hoping you guys can help me,
I’ve got a 2007 r56 Mini Cooper D, it’s developed a fault where I can start the car and drive for a couple of minutes as normal then it will lose power and not rev over 3k. It doesn’t get any warning lights on when this happens, I can turn the car off and back on again and it will drive ok for a few minutes then same again back into limp mode.
I’ve fitted a new fuel filter hoping it was something simple.
My mam has the same car so I’ve tried swapping Maf, boost sensor, throttle body including boost pressure sensors and still same fault.
Any ideas?
h2xby is offline
post #2 of 10 (permalink) Old Jun 24th, 2019, 01:18 PM Thread Starter
Quoted: 2 Post(s)
Also I’ve tried cleaning the EGR, and swapped it with my mothers and still no luck
h2xby is offline
post #3 of 10 (permalink) Old Jun 24th, 2019, 01:33 PM
Local Time: 11:41 PM
Quoted: 677 Post(s)
fuel filter first thing to replace have had cars the same as partially blocked filter car runs fine until demand load on it then just gets worse,
good tuners/repairs in southwest uk top guys 01579388980
good tuner/ecu body control clones etc lancaster up north uk DALE PHONE NUMBER 07807 222262 top guy.
mike1967 is offline
post #4 of 10 (permalink) Old Jun 24th, 2019, 02:04 PM Thread Starter
Quoted: 2 Post(s)
I’ve changed the fuel filter, also incase it was a duff one I’ve swapped the filters with the other car and it’s the same
h2xby is offline
post #5 of 10 (permalink) Old Jun 24th, 2019, 02:59 PM
Quoted: 71 Post(s)
Sounds the same as mine was a couple of months ago. Turbo boost control valve was faulty didn't throw up eml and no codes at first until it got really bad.
Stu
Stu E is offline
post #6 of 10 (permalink) Old Jun 24th, 2019, 03:38 PM Thread Starter
Quoted: 2 Post(s)
Stu
Is that the one on the rear of the engine?
h2xby is offline
post #7 of 10 (permalink) Old Jun 24th, 2019, 04:20 PM
Quoted: 71 Post(s)
Stu
That's the one
Stu E is offline
post #8 of 10 (permalink) Old Jun 24th, 2019, 08:25 PM Thread Starter
Quoted: 2 Post(s)
I've had a break though, when i disconnect the EGR electrical connector the car works as it should and doesn't go into limp mode.
I've tried changing the EGR motor or whatever it is from the other car and that doesn't fix it but when i disconnect it, its fine!
Would you's say to try changing the full EGR system with cooler and the vac pipe that goes to the inlet?
h2xby is offline
post #9 of 10 (permalink) Old Jun 25th, 2019, 07:41 AM
Quoted: 677 Post(s)
egr valve needs to be programmed with diagnostics tool after replacing and adaptation reset ,, below software will do it plus a lot more,
autocom cdp plus
https://www.ebay.co.uk/itm/Bluetooth...a04154a95118db
mike1967 is offline
post #10 of 10 (permalink) Old Jun 25th, 2019, 08:04 AM Thread Starter
Quoted: 2 Post(s)
Ah ok! I’ll try that then!
Thanks!
h2xby is offline
