Roof opens but warning light says its not fully open - MINI Cooper Forum
Second Generation MINI Convertible MINI Convertible (MINI Cabrio) 2009 - Present
post #1 of 5 (permalink) Old Apr 14th, 2018, 08:52 PM Thread Starter
Local Time: 07:27 AM
Quoted: 1 Post(s)
England Roof opens but warning light says its not fully open
Hi All I've recently bought a 2010 cooper convertible and have found that although the roof seems to open fully its coming up with a warning (showing the roof down and a padlock) its saying the roof isn't open fully and gives a warning noise if I go over 20mph. I know about the sensor in the boot to enable it to open but is there another to say its fully open?
thanks Matt
Last edited by Mathewg2004; Apr 14th, 2018 at 10:00 PM. Reason: didnt give original post a tag or title
Mathewg2004 is offline
post #2 of 5 (permalink) Old Apr 15th, 2018, 06:30 AM
Quoted: 631 Post(s)
thanks Matt
need to have it scanned it will show which sensor/switch is faulty, the system has sensors and switches that tell the roof ecu/body control module where the roof is as such, its common for these to fail break or sometimes some adjustment might be all it is,, without diagnostics that will work with it its like finding a nail in hay stack.. i'm not aware of any bypass for the warning on it as its so important for safety that the roof is locked either way in the eyes of the makers.. i done a Renault convertible once and that was truly a total pain turned out all the linkages that held roof to car were worn out form the roof always being used up and down.. 2mm of wear at a fixing point might be 20mm or travel at end of a arm and thats what a sensor will pick up...
all you could try is stripping out all covers and wd40 all fixing points and any switched on some they are part of the hydraulic rams and tend to be non replaceable without changing a ram.
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is online now
post #3 of 5 (permalink) Old Apr 15th, 2018, 08:50 AM Thread Starter
Quoted: 1 Post(s)
Thanks seems I'm off to a dealership. Has anyone ever used westerly mini in Bridgwater Somerset?
post #4 of 5 (permalink) Old May 4th, 2018, 01:32 AM
tvanstelle's Avatar
Local Time: 01:27 AM
Quoted: 2 Post(s)
United States Male
Garage
Roof/Hood issue
On my R57 when the top seems like it is done moving, there is a pause and it settles down a bit more..If i stop at the pause, the light stays on solid
When i bring it half way up and watch it in my mirror, when i see that last bit of movement it is great and the light goes off
[FONT="Comic Sans MS"][/FONT]
Tom Van Stelle
tvanstelle is offline
The Following 2 Users Say Thank You to tvanstelle For This Useful Post:
post #5 of 5 (permalink) Old May 15th, 2018, 12:34 PM
D&B
I have had the same problem for over a year, just haven't had the roof down until today. I think the answer is to look for simple problems before getting too involved with fault codes and trying to decipher them etc.
Just solved my problem. There was a foreign body stuck in the locating recess that a pin is supposed to drop into either side adjacent to the rear windows. I had 3 fault codes A69A A69C & A6A3 which I could not find an explanation for. Spent ages trying to track down what these codes meant, when I should have looked for obvious visible problems! Strangely enough I cleared the fault codes before finding the obstruction and they didn't come back again?
Hope this may help someone.
D&B is offline
The Following 2 Users Say Thank You to D&B For This Useful Post:
MattyG Mathewg2004 Welcome New Members 1 Apr 14th, 2018 08:44 PM
