No boost when cold - MINI Cooper Forum
 1Likes
  • 1 Post By WOE2
post #1 of 8 (permalink) Old Nov 22nd, 2018, 11:17 AM Thread Starter
Local Time: 11:55 AM
Quoted: 1 Post(s)
Scotland Male
Garage
Scotland No boost when cold
Hi, I am having issues with no boost, we had codes initially for the Blow Off Valve and so fitted a new one, but still having problems, we scanned the car on Delphi and had fault codes for the Bypass Blow Off Valve, and again when we went to look at its function on the diagnostics it would show it not active when accelerating, but we have found that when the car gets fully up to temp to the point where the fan cuts in for first time, that then suddenly the car performs properly with full boost, and when scanned shows no fault codes and when we look at the function on diagnostics we can see the Blow Off Valve activating on acceleration, and the car runs fine unless you let it cool down again. So we are not sure if this is a fault with the Blow Off Valve or not, any advice would be much appreciated? The car is standard without any mods.
steffmax is offline
post #2 of 8 (permalink) Old Nov 22nd, 2018, 03:00 PM
Quoted: 678 Post(s)
its very common for the linkage between the actuator for waste gate and the penny valve in the exhaust side of turbo to wear out, worth checking the vac control circuit to actuator from vac pump on side of head, ie psi feed and whether the solenoid valve that controls it is working right, have known these to under heat work or not work as wingdings expand etc . just follow the vac pipe from turbo back to the solenoid, all this valve does is be a valve on and off to work the waste gate lever thats where i would start
good tuners/repairs in southwest uk top guys 01579388980
good tuner/ecu body control clones etc lancaster up north uk DALE PHONE NUMBER 07807 222262 top guy.
mike1967 is online now
The Following 2 Users Say Thank You to mike1967 For This Useful Post:
post #3 of 8 (permalink) Old Nov 22nd, 2018, 03:54 PM
Local Time: 12:55 PM
Quoted: 9 Post(s)
United Kingdom Male View WOE2's Classified Ads
Garage
Mine was also not boosting when cold. I replaced the blowoff valve but it made no difference.
Finally I bit the bullet and whipped off the turbo and found my wastegate stuck open. The pivot was worn causing the flap to jam open.
The good news is you can buy the exhaust housing for £150 and itís a pretty easy swap.
Jason
ID:	226705   Click image for larger version
mike1967 likes this.
WOE2 is offline
The Following 2 Users Say Thank You to WOE2 For This Useful Post:
post #4 of 8 (permalink) Old Nov 25th, 2018, 05:18 PM Thread Starter
Quoted: 1 Post(s)
Scotland Male
Garage
Thanks for replies so far this gives me a couple of things to check myself, as i really want to avoid sending to a garage for an expensive fishing operation, any more advice is gratefully received, and i'll update with my findings. Thanks again.
steffmax is offline
post #5 of 8 (permalink) Old Nov 26th, 2018, 08:19 AM
Quoted: 9 Post(s)
Garage
Check vac hoses and tank.
WOE2 is offline
post #6 of 8 (permalink) Old Dec 8th, 2018, 04:04 PM
Quoted: 5 Post(s)
My Mini Cooper has over 50,000 miles.What should consider replacing the water pump and thermostat?
So that, it can save hours of labor if I replace them before finding a leak.
clint.dempsey is offline
post #7 of 8 (permalink) Old Apr 18th, 2019, 04:38 PM Thread Starter
Quoted: 1 Post(s)
Scotland Male
Garage
Hi, sorry so long in updating, as I've not had a chance to work through some of this advice until now. So far I have replaced myself: Diverter Valve, Throttle Body, Engine Valve Cover, Turbo Boost Solenoid Valve, Tank Vent Valve Breather Solenoid, Vacuum Tank, i've also checked wastegate action on turbo and it operates properly using a vacuum gauge, and i'm still having the same issue of no boost when cold with fault codes for Diverter Valve, then when it's fully up to temperature the car boosts and goes correctly and shows no fault codes. I refitted my old Diverter Valve too thinking maybe I'd got a faulty new one, but made no difference and in fairness both Diverter Valves look in good shape with no tears or splits. I'm pulling my hair out, anyone got any further thoughts as to what could be causing the problem, again any help much appreciated?
steffmax is offline
post #8 of 8 (permalink) Old Apr 18th, 2019, 09:01 PM
Quoted: 9 Post(s)
Garage
My wastegate appeared to work fine when I tested with a vac pump.
I have had no problems after replacing it.
WOE2 is offline
Tags: , , ,
ICE Link Plus with CD Boost - No Text and No Menu MaKSiNG First Generation Interior & Ice 0 Jul 11th, 2009 07:41 PM
no income tax no vat, no money back no guarantee Mike Schumacher Second Generation Interior & Ice 4 Feb 26th, 2007 11:09 PM
ProMini Cold Air Intake VS Alta Cold Air Intake??? SS Mini First Generation MINI Tuning 5 Dec 13th, 2005 12:48 AM
LIGHTS, no lights, LIGHTS, no lights, LIGHTS, no lights etc sleepyrascal First Generation Faults & Fixes 8 Nov 8th, 2005 10:01 AM
Cold, cold cold (frozen gearbox problem) MINIHAHAHA First Generation Faults & Fixes 3 Jan 21st, 2003 01:32 AM
