2007 S Model Fault Code Help Please - PO341 - MINI Cooper Forum
post #1 of 2 (permalink) Old May 21st, 2019, 05:35 AM Thread Starter
Jerry Kraus
Local Time: 03:56 AM
Quoted: 1 Post(s)
United States Male
Hi All,
My wife just acquired a 2007 Mini Cooper S with 28,000 miles on it. She has not had it even a month and the check engine light came on with 2 of the same codes: "PO341 Camshaft Position Sensor A Circuit Range / Performance Bank 1 or Single Sensor"
I also noticed that when she drives around a corner the engine oil symbol (oil can) light would come on for a second. I looked it up and the manual said add a quart of oil, so I did. I've never had a car start burning oil at 30,000 miles, is that normal for a 2007 Mini Cooper S?
Thank you all in advance for your help...
Name:	Mini Cooper Codes 5.20.19.jpg
Jerry Kraus is offline
post #2 of 2 (permalink) Old May 21st, 2019, 10:39 AM
Quoted: 663 Post(s)
Originally Posted by Jerry Kraus View Post
Hi All,
all makers except honda do this trick these days ie designed low friction bores and pistons and use oil vag groups v6 petrols are silly for using oil 1 litre to 200 miles common, prince engines use a tad as well,, its worth doing a seafoam in engine oil run car for 100 miles this will clean out any crud in piston rings, as you have run it low on oil chances are damage is done rule of thumb when light comes up on dash for oil pressure its to late,
this all said need to have timing chain checked also need to know what the vanos sprockets are doing when can running,, its very common that oil starved engines will wear the metal oil control rings inside the camshafts on first journals that send oil to the vanos sprockets these sprockets alter the cam timing from oil pressure,, you might be luck and oil and never let oil get lower than full mark again,, little tip if you co to europarts and ask for 5/30 low saps oil suitable for mini cooper s they do a 20 litre drum for around 45 ie 4 gallons 11 ish per gallon of oil.. beats the 35 that some pay for a 4 litre can of other branded oil.
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
The Following 2 Users Say Thank You to mike1967 For This Useful Post:
Please help! 2E67 fault code Bingo454 Second Generation Faults & Fixes 8 Oct 2nd, 2018 07:31 PM
2007 Cooper S fault code B1CAE (9CAE) Jummi Second Generation Faults & Fixes 0 Aug 8th, 2017 06:25 PM
Fault Code 102 1E - what does it mean please? mikepaterson Maintenance & MINI Care 0 Feb 1st, 2016 12:24 PM
Fault code help (please) mini-millie-n-dan First Generation Faults & Fixes 17 Dec 21st, 2010 05:49 PM
help with fault code please P0030 02 rallycross First Generation Faults & Fixes 9 Oct 24th, 2007 05:30 AM
