Throttle position sensor/ VANOS adaptation - MINI Cooper Forum
Second Generation MINI One MINI One from 2007 - Present
post #1 of 4 (permalink) Old Dec 26th, 2018, 12:00 AM Thread Starter
Local Time: 11:57 AM
Quoted: 6 Post(s)
I have been having issue with moving car on first gear, from full stop. it feels like car loosing power after clutch engages, the remedy was to press more on accelerator pedal to increase revs.
So essentially I have need keeping higher revs to start move the car.
this issue was always with the car, when we bought it.
so far changes, clutch, new gearbox, timing chain, issue still exist.
ps, i did all the fixes not to fix just this issue, it was other unrelated issues.
recently cleaned the pressure sensor and throttle body. new oil and air filter.
My suspicion is Throttle position sensor need adaptation or maybe VANOS motor need adaptation.
Any suggestions how to do them?
Denys Milano is offline
post #2 of 4 (permalink) Old Dec 26th, 2018, 08:20 AM
Quoted: 600 Post(s)
have you done a diagnostics scan, if have with what scanner and what did you find, did you do a live data scan and see that after timing chain was done that it was timing correctly,, as for adaptation there is a way around this i do it all the time,, car needs to be run from cold to hot ie 3 10 miles runs in-between letting car go cold, this process if ecu is working correctly and more importantly if all faults have been cured will relearn its adaptations..
this all said if you dont have access to deep enough diagnostics its impossible to work the problems out, list below of must have tools,
oil pressure tester,
compression tester.
multimeter
autocom cdp plus diagnostics easy one to use fairly cheap, 30 ish on ebay.
or wow wurth snooper diagnostics,
or insta p and d bmw software, but a lot harder to use and install.
i have lost count the amount of times someone has private messaged me after trying to fit a timing chain and realised they had got it wrong dont take much,
mike1967 is offline
post #3 of 4 (permalink) Old Apr 13th, 2019, 12:59 AM Thread Starter
Quoted: 6 Post(s)
compression tester.
multimeter
I am kind of suspecting MAF sensor, what are the values you should see on MINI r56 1.4 V753506980, vonder if anyone knows?
ALso mike1967 how can I tell if timing is off by looking at the ODB scaner?
post #4 of 4 (permalink) Old Apr 13th, 2019, 08:04 AM
Quoted: 600 Post(s)
ALso mike1967 how can I tell if timing is off by looking at the ODB scaner?[/QUOTE]
yes i can with autocon cdp can see the prescribed and actual positions of vanos,
belowscreen shots off a fully working correctly 1.4 mini one
Name:	1.4 on idle lean weak 02 sensors.jpg
ID:	228015   Click image for larger version
Name:	1.4 on idle 02 sensors.jpg
ID:	228017   Click image for larger version
Name:	1,4 on idle vanos positions.jpg
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
Cooper vanos gear position Cbatoday Second Generation MINI Cooper 29 Aug 11th, 2017 06:01 PM
2003 Mini Cooper R50 Throttle Position Sensor P1125 darrena96 First Generation Faults & Fixes 0 May 18th, 2015 12:48 PM
Throttle position sensor PN or vendor tgreene73 First Generation MINI Tuning 1 Sep 4th, 2010 01:22 AM
Throttle Position Sensor Signal Yellow/Black OneD First Generation MINI Tuning 0 Apr 30th, 2006 08:09 PM
ECU Adaptation clip from European Car... TomM First Generation MINI Tuning 3 Jan 17th, 2003 02:57 PM
