What make of thermostat - MINI Cooper Forum
Second Generation MINI One MINI One from 2007 - Present
post #1 of 3 (permalink) Old Jan 29th, 2019, 10:38 PM Thread Starter
Local Time: 07:32 AM
Quoted: 21 Post(s)
Hi need some advise, I need to change Euro carparts thermostat I fitted only lasted six months!!! On my 2008 1.4 mini one. What’s a good OEM part and should I replace pipe that goes to water pump as well? Also looking to replace cylinder head seals, what’s a good kit and sealant to buy? Thanks
Mage 1 is offline
post #2 of 3 (permalink) Old Jan 30th, 2019, 04:47 AM
Quoted: 299 Post(s)
What make of thermostat were you supplied by euros? Was it circoli as I believe they can be a bit hit and miss.
Other option is dealer but at around 120 it can make your eyes water
Unless the pipe is split or damage I use the old one. Good luck with the metal clip
Do you mean valve cover seals rather than cylinder head then a good brand is fai and they can be found on Ebay. unless leaking or split I have reused originals
You want a good quality rtv sealant just to put a dab in the corners on the vac pump end of the head
Leave it to set for about 10 mins then reassemble and torque bolts to 10 nm or risk damaging seals
Cbatoday is offline
post #3 of 3 (permalink) Old Jan 30th, 2019, 07:56 AM Thread Starter
Quoted: 21 Post(s)
Thanks for that and yes it was a circoli, at least I’ll get my money back but not my time!!! Sorry meant valve cover seals will look on eBay. Thanks for the tip!
Mage 1 is offline
replace thermostat and housing or just thermostat wrx fifer First Generation MINI Cooper S 7 May 26th, 2014 05:33 PM
First and Last - Make A Wish, Make A Difference ..... SoggyCornFlakes General Discussion 3 Jan 29th, 2008 07:56 PM
What MINI wanted to make, and what a supplier SHOULD make... Paul First Generation Interior & Ice 11 Feb 15th, 2004 08:21 PM
thermostat ? presurized mini First Generation MINI Tuning 0 Sep 7th, 2002 10:37 AM
Is there an oil thermostat for oil cooler? jmardy First Generation MINI Cooper S 17 Jul 22nd, 2002 04:59 AM
