No cat wtf - MINI Cooper Forum
Second Generation MINI One MINI One from 2007 - Present
post #1 of 6 (permalink) Old Feb 16th, 2019, 11:27 AM Thread Starter
Local Time: 05:18 AM
Quoted: 299 Post(s)
No cat wtf
On with changing the cat on the mini one after getting permanent cat below threshold code.
Well the old cat is off and wanted to get an idea of the condition of the innards
Shone the torch town there and nothing. so at some stage the cat has been gutted and welded back up.
Question is how has the car passed an mot last Sept. The mot was done after the valve stem seals were changed whilst the head was in situ.
Maybe the seals wernt changed and the cat gutted to pass emissions
What do you think
Cbatoday is offline
post #2 of 6 (permalink) Old Feb 16th, 2019, 05:37 PM
Quoted: 631 Post(s)
What do you think
burnt away maybe if no weld marks on cat. ho bugger one of the first things on the list just goes to prove cant take nothing for granted,, i bought a 2.2hdi powered 4x4 the other day for family hack, guy was really nice RAF pilot not short of a few quid.. service history looked all good serviced 7k ago and its on 70k so due a timing belt and water pump anyway.. when i started the service found air filter covered in black soot and grass etc ie been in there for over 30k without doubt, the oil was loaded with carbon,, ad when looked in at timing belt, it had just had the top oil cam seals replaced nothing else and all the belt and front covers were lagged in dirty oil from and the belt,, ie they had gone to trouble of removing the belt enough to change the seal behind it then stuck it back together and sold it on... cant trust no one when buying a car, cant take nothing for granted, expect the worst anything else is a bonus, in your case seeing is believing ie looking inside the cat when have codes related to low cat codes.
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
post #3 of 6 (permalink) Old Feb 16th, 2019, 09:40 PM Thread Starter
Quoted: 299 Post(s)
No weld marks on cat. Could the cat have self destructed with all the rich fuel and oil and heat and spat it out of the exhaust tail pipe
Would a vehicles engine loose back pressure in this situation and therefore oil pressure drops
Cbatoday is offline
post #4 of 6 (permalink) Old Feb 17th, 2019, 06:58 AM
Quoted: 631 Post(s)
more like the other way around the engine feeds the cat oil and rich fuel mixture and melts away the cat over time, oil pressure maybe effected from low oil levels at some points of its life and worn the crankshaft
mike1967 is offline
post #5 of 6 (permalink) Old Feb 17th, 2019, 11:55 AM
cristo
cristo's Avatar
Local Time: 12:18 AM
Quoted: 37 Post(s)
United States Male View cristo's Hot Chocolate & Silver 2nd Gen MINI John Cooper Works Clubman Profile
Garage
I think it’s more likely the cat
failed and got restricted and
someone busted the cat out
as a quick fix for that.
cristo is offline
post #6 of 6 (permalink) Old Feb 17th, 2019, 01:03 PM
Quoted: 631 Post(s)
Originally Posted by cristo View Post
I think itís more likely the cat
its not that easy the top of cat has the 4 branch manifold welded to it, and the bottom end has a narrow 90 degrees bend in it,, i know from past dpf filter knocking through that without a good straight access to the filter part it impossible to knock them out..
mike1967 is offline
No 2 Spoke Steering Wheel for 2005....WTF Choprpilot76 First Generation MINI Cooper S 9 Oct 27th, 2014 08:57 PM
no income tax no vat, no money back no guarantee Mike Schumacher Second Generation Interior & Ice 4 Feb 26th, 2007 11:09 PM
CAT or no CAT Fisher First Generation MINI Tuning 8 Apr 8th, 2006 05:10 PM
Cat D or not Cat D, that is the question Blusox First Generation MINI Cooper 6 Jul 14th, 2005 05:36 PM
Milltek with sport cat or de-cat?? oceanstarBug First Generation MINI Tuning 1 Apr 17th, 2005 08:13 PM
