PCV hose, delete. - Page 4 - MINI Cooper Forum
Second Generation MINI Tuning
Tuning the second generation MINI Late 2006 - Present
 1Likes
post #46 of 49 (permalink) Old Dec 17th, 2016, 09:53 PM
Local Time: 01:36 PM
Quoted: 2 Post(s)
Hi,
I believe one of the guys asked the question, I have been wondering but there is no answer. (Unless my dumb butt missed it). Instead of deleting the PCV hose on left side could one just add a Catch can to prevent oil from entering the intake thus preventing build up?
emt3c is offline
post #47 of 49 (permalink) Old Jun 1st, 2017, 03:24 AM
Registered User
Can you tell me where I can get the plugs from? When I try to look them up I only seem to find then overseas.
thegremlin69 is offline
post #48 of 49 (permalink) Old Jun 11th, 2019, 08:42 PM
Hello,
So I got the same situation as described by all users, a lot of oil consumed by the N12 motor, as I read the caps 0361S4 would do the trick, but I did not find the information regarding this particular engine, all the info is about the turbo version (N14) *hope I did understand it right*.
So the question is if anyone has installed the caps on the N12 engine, did you have any problems, @Czar I understand that you are the specialist in this domain does it have the second PCV valve also? Hope you are still active on the forum.
Maria Ilinca is offline
post #49 of 49 (permalink) Old Jun 12th, 2019, 09:45 AM
knt
Quoted: 52 Post(s)
Not sure if the N12 has the PCV like the N14 engines, but I wouldn't recommend deleting the PCV as it's needed for proper engine running.
If the car is consuming oil, it could be for lots of other reasons. Check the valve cover and if it has the PCV system try replacing the valave cover or buy the PCV repair kit.
Google "N12 PCV membrane".
mike1967 likes this.
knt is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
intake hose resonator delete vinniecooper First Generation MINI Tuning 1 Jan 22nd, 2011 12:55 PM
forge Intercooler Reasonator delete hose argyris Second Generation MINI Tuning 20 Jul 28th, 2009 08:59 PM
Cleaning... Without a Hose.. envy Maintenance & MINI Care 10 Jun 12th, 2009 07:42 AM
Fitting Resonator Delete Hose Rosco Second Generation MINI Tuning 4 Feb 3rd, 2009 02:26 PM
PCV hose pics? DarkMiniCooperS First Generation Faults & Fixes 5 May 10th, 2004 02:37 AM
