Used JCW - Page 2 - MINI Cooper Forum
Second Generation Works MINI John Cooper Works and MINI WC50 2007 - Present
 1Likes
post #16 of 17 (permalink) Old Apr 6th, 2018, 11:45 AM
Spatt's Avatar
Local Time: 08:54 AM
Originally Posted by Austin_CS View Post
Search for 'death rattle', or timing chain, or timing chain tensioner, or timing issues on this or any other MINI forum, and you'll see many multiple threads on the issues that several incarnations of the engine have.
Bottom line: Change your oil every 5-6k (miles) - ignore the manufacturer recommendation of 10-12k and use DECENT oil that surpasses LL04 standard (5w-30) - change the timing kit every 50k regardless of how you drive. If your model has done close to, or over, a 50k multiple and you can't see any service record that states the timing kit has been replaced - change the kit!
The chain stretches past the point where the tensioner can adjust it and the timing goes to hell in a handcart. The tensioner can break, or wear away, long before the stated interval. poor quality oil or excessive intervals between changes will exacerbate this wear.
Ignore the death rattle at the peril of destroying the engine.
Check the service history with care.....
Good Luck!
Thank you for your advice, is this something still prevalent on the newer' engine "N18" is it... 2012 models have?
I have a friend with a ramp and have always changed my oil twice a year. IS the timing chain kit replacement expensive? could it be done with basic tooling and a ramp?
thanks in advance
Matt
Spatt is offline
post #17 of 17 (permalink) Old Apr 13th, 2018, 09:42 AM
Austin_CS's Avatar
Quoted: 20 Post(s)
Garage
Timing chain kits can be found on eBay for around 200 in the UK. I can't speak to their quality as I am not a mechanic, a proper newbie on car DIY, and haven't changed mine yet, but reading (with some trepidation) the many responses on this, what I think I can state is that cheap tensioner kits will always let you down. Main Stealers will give you Bimmer parts for a King's ransom but adequate quality spares can be found cheaper on the W3.
As to the actual task itself - I would definitely look for Mike1967's many, many posts on here advising great care and attention (Quite a few other posters too, but from memory, Mike has responded most on this). From what Mike writes, you only get one chance to get the timing right without starting all over, and stability / immobility of the moving parts when setting the chain is absolutely critical. It is a fiddly job, I would get a trained Mini / Peugeot mechanic to do my 2010 MCS (Prince engine). And I'll probably look for recommendations on here first , as it seems to be a classical case of experience over training for these engines.
Tools - see the other posts on that, but I would want a torque wrench and the (good quality) special timing tool or I wouldn't dream of starting.
Later models - Anyone out there care to comment?
Austin_CS is offline
Help! Possible fake Countryman JCW. rmarsono MINI Countryman 11 Nov 10th, 2015 10:22 PM
2014 S vs 2014 JCW in roadster form... Miniologist General Discussion 2 Nov 3rd, 2015 11:06 PM
My 2004 MCS JCW - what's it worth Jonny3979 First Generation Works 6 Sep 11th, 2013 11:13 AM
My JCW GP2 Czar Second Generation Works 7 Jul 23rd, 2013 11:41 PM
JCW Adventures & The Birth of a JCW AMAUTOS7 Second Generation Works 9 Nov 6th, 2012 07:57 PM
