2015 mini cooper f56 driver side door latch won't open from the inside. - MINI Cooper Forum
post #1 of 2 (permalink) Old Jul 29th, 2018, 06:04 PM Thread Starter
Local Time: 12:24 PM
It looks like there's a metal latch that has become detached from a small, white piece of plastic inside the door handle on the driver's side. I've attached a few pictures to better show the problem. Is the simple solution to just pop it back into place?
ID:	225645   Click image for larger version
Tncrumpets is offline
post #2 of 2 (permalink) Old Aug 9th, 2018, 08:52 PM
SteveM3's Avatar
Local Time: 01:24 PM
Quoted: 29 Post(s)
England Male View SteveM3's  & Silver 3rd Gen MINI Cooper Profile
As long as there is a cable attached to the white plastic it should work but can you see why it came off in the first place?
[SIGPIC][/SIGPIC]
SteveM3 is offline
Stiff Bonnet Latch Hood Won't Open Andrew Grass MINI Coupe and MINI Roadster 0 May 17th, 2016 01:00 AM
PAssenger Door won't open from inside using the handle couchiedemon First Generation Faults & Fixes 4 Aug 29th, 2014 11:51 AM
Driver door will not open from inside or outside dani.808 General Discussion 1 Oct 6th, 2011 06:31 PM
Glovebox latch & door latch Faxo First Generation Faults & Fixes 1 Jul 6th, 2010 09:31 PM
driver side door latch/tweeter housing problem btdoyle First Generation Faults & Fixes 1 Jun 26th, 2010 07:04 PM
