Help! Have coolant leak and need advice!! - MINI Cooper Forum
 1Likes
  • 1 Post By yellowkid
post #1 of 5 (permalink) Old Apr 1st, 2018, 02:58 PM Thread Starter
Local Time: 11:31 PM
First I have a 2014 Mini Cooper S AWD 6-spd -- not sure what a 3rd Gen is (!) but hopefully I'm in the right place. I've got a coolant leak in the front of the motor and I'm hoping it will look familiar to someone who can give me a best guess at what is leaking? Photos attached. It may be hard to see, but it's coming down directly above the exhaust sensor, working it's way down to the exhaust itself eventually. I saw it on the garage floor and it continued to drip for a while to form a small puddle after about 30 min. I can't really get in there to see well enough to diagnose; so I can't really judge whether this is do-able for me (been working on cars for 45 years) or better to give to the dealer. Hoping for some input here from those with more experience to aid my decision! thanks very much. john p
ID:	224177   Click image for larger version
ID:	224179   Click image for larger version
ID:	224181   Click image for larger version
yellowkid is offline
post #2 of 5 (permalink) Old Apr 1st, 2018, 04:25 PM
Moderator
minione2002's Avatar
Quoted: 625 Post(s)
She's a 3rd gen..
my best guess is a leaking thermostat gasket
Have you checked all the pipes for damage?
Are all the pipe Hose clamps tight?
minione2002 is offline
post #3 of 5 (permalink) Old Apr 1st, 2018, 05:00 PM Thread Starter
thank you -- checking now....
minione2002 likes this.
post #4 of 5 (permalink) Old Apr 1st, 2018, 05:44 PM Thread Starter
everything visible without taking anything apart is dry and OK. It must be right in close to the block. which sounds like the thermostat. Is this a DIY? Do they hit you hard for this?
post #5 of 5 (permalink) Old Apr 1st, 2018, 06:28 PM
Moderator
Quoted: 625 Post(s)
I've never done it, so can't say tbh.
@mike1967 might have some info he is a variable fountain of info!!
He'll be along in a minute, i've summoned him
Coolant Leak Engine Overheated. Advice needed wurdup Second Generation Faults & Fixes 1 Dec 24th, 2015 04:03 AM
Oil Leak or Coolant leak MeanGreen7 First Generation MINI Cooper S 3 Feb 17th, 2014 04:17 PM
Coolant leak advice Bissell First Generation Faults & Fixes 3 Nov 6th, 2012 10:46 PM
Coolant Leak Need Help RonB352 First Generation MINI Cooper S 5 Nov 1st, 2010 10:43 PM
Coolant Leak, need help and advice please !! Actionman First Generation Faults & Fixes 3 Jul 11th, 2008 11:26 AM
