Coolant expansion tank return line help! - MINI Cooper Forum
Welcome New Members New members, please introduce yourself here. Tell us a bit about you and your Mini.
post #1 of 4 (permalink) Old Feb 12th, 2015, 10:28 PM Thread Starter
Local Time: 04:34 AM
United States Male
Garage
Hey, I'm a new member on here but a lifetime fan of minis, but by no means a pro. I bought a 2004 JCW yesterday and drove it 150 miles home and the engine started to overheat. I popped the hood and saw that the return line to the expansion tank was unattached and that the nipple of its connection spot was broken off. I have no idea where this plugs in to or what part I will have to buy to replace the broken nipple. Any help will be appreciated!!!
MacLeod Dickey is offline
post #2 of 4 (permalink) Old Feb 13th, 2015, 04:12 PM
Quoted: 24 Post(s)
Can you post a photo?
But if it is a return hose to the expansion tank it should fit on to the tank close to the power steering header tank.
If the pipe is disconnected then presumably the expansion tank is not pressurised when the system is hot and in fact the whole cooling system will not be pressurised so the engine will boil over at way too low temperature and overheat very quickly.
Driving it far in this state is likely to lead to a blown cylinderhead gasket!
Spike
ihughes is offline
post #3 of 4 (permalink) Old Feb 13th, 2015, 05:59 PM
cristo
cristo's Avatar
Local Time: 12:34 AM
Quoted: 37 Post(s)
United States Male View cristo's Hot Chocolate & Silver 2nd Gen MINI John Cooper Works Clubman Profile
Garage
Look at this diagram on realoem.com
RealOEM.com * BMW R53 Cooper S EXPANSION TANK/TUBING
You can get the part numbers off of it and order at a MINI dealer,
PelicanParts.com, ECStuning, etc.
If the nipple's broken off, you'll need a new expansion tank 17137529273
Can even get an aftermarket expansion tank instead if desired.
Here are some options:
Search SiteSearch 17137529273 - ECS Tuning
cristo is offline
post #4 of 4 (permalink) Old Feb 14th, 2015, 12:53 AM Thread Starter
United States Male
Garage
Thanks!
Thank you ihughes and cristo both, the link to ECStuning was exactly what I needed! The part called the T-connector. I'll let you know how it goes, thanks again!
Tags: , , , , , ,
Coolant expansion tank fully empty Petpiemel Second Generation Faults & Fixes 2 May 22nd, 2014 10:01 PM
R53 Overheated Hollywood First Generation Faults & Fixes 71 May 13th, 2014 05:30 PM
Expansion Tank jrwestham Second Generation Faults & Fixes 2 Feb 18th, 2014 11:05 PM
Fiting an Alloy coolant header tank on Gen 1 MCS ihughes First Generation Faults & Fixes 4 May 14th, 2013 08:39 PM
added coolant in the wrong tank? PANIC target121 First Generation Faults & Fixes 16 Sep 28th, 2012 05:05 PM
