2009 Cooper S EML/Fan problems - MINI Cooper Forum
Welcome New Members New members, please introduce yourself here. Tell us a bit about you and your Mini.
post #1 of 4 (permalink) Old Apr 9th, 2019, 07:56 PM Thread Starter
Local Time: 12:56 AM
Quoted: 1 Post(s)
Hi all,
Looking for some advice.
I've recently got a 2009 Cooper S. A week later the water pump went so had that replaced from the garage I bought it off. Since then the fan will run constantly when engine off. After a journey if I turn the car off the next time I try to start it the car will just turn over on the first push and then start on the second. EML then comes on and it usually has a code stored P0117 P2F1A. Car seems to be holding back in 2nd and 3rd as well.
Any ideas?
Gearzy is offline
post #2 of 4 (permalink) Old Apr 10th, 2019, 07:51 AM
Quoted: 650 Post(s)
Originally Posted by Gearzy View Post
Hi all,
Any ideas?
if you have checked coolant temp sensor and thermostat is all working fine,, have you at any time removed the two larger water pipes for radiator ie one is top one and the other is bottom depending on flow direction,, if these are connected the wrong way round it causes a air lock in the thermostat housing and makes the temp sensor sit in air and not water this causes the car to think its cold when should be g=hot and the other way around depending on how far driven ie how much heat is the rest of the system,
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
post #3 of 4 (permalink) Old Apr 10th, 2019, 07:53 AM
Quoted: 650 Post(s)
you will also need to reset any eml codes after and re bleed the system big bleed screw on thermostat housing.. autocom cdp plus or wurth snooper good gear for it,
mike1967 is offline
post #4 of 4 (permalink) Old Apr 10th, 2019, 02:14 PM
Hmm
AnonOdy is offline
EML light problems blackflamer First Generation Faults & Fixes 7 Jan 25th, 2019 05:48 PM
2002 cooper fan cooling fan Matt Moorhouse First Generation Faults & Fixes 0 Mar 31st, 2015 03:45 PM
cooling fan change on 2009 s..help newby googie Maintenance & MINI Care 0 Sep 5th, 2012 06:52 AM
Power Steering goes out, high speed fan and power steering fan aren't staying on. Niko First Generation Faults & Fixes 3 Jul 7th, 2008 01:25 PM
PS fan, main fan eddieboyII First Generation MINI Cooper S 1 Jun 30th, 2004 05:16 AM
