R50 run flats - MINI Cooper Forum
Wheels, Tyres & Brakes
Sponsored by:
post #1 of 5 (permalink) Old Feb 21st, 2019, 08:18 PM Thread Starter
Local Time: 01:05 AM
Scotland Male
R50 run flats
Hi guys I have a 2006 R50 it’s in mint conditioning both the mechanic and the guy that fitted my new exhaust have said they’ve never seen one with an underneath in such amazing condition so it’s definitely something to be proud of! I currently have it running on 4 Pirelli P-Zero run flats however the front two are balding so they need replaced. Does anyone know a cheap place to find Pirellis because I want to keep them all the same but as much as I love the car £270 for two tires seems excessive! Thank you 😎
Benjav22 is offline
post #2 of 5 (permalink) Old Feb 25th, 2019, 01:12 PM
Peppers Pray's Avatar
Quoted: 17 Post(s)
Garage
Go non runflat..... replace them all for the same money, improve the ride, live on the edge with a puncture repair kit to hand. (oooh danger )
P
Drink Hydrocarbons, Spit Fire
Peppers Pray is offline
post #3 of 5 (permalink) Old Feb 25th, 2019, 01:13 PM
Quoted: 17 Post(s)
Garage
Go non runflat..... replace them all for the same money, improve the ride, live on the edge with a puncture repair to hand. (oooh danger )
P
post #4 of 5 (permalink) Old Mar 24th, 2019, 05:19 PM
Quoted: 1 Post(s)
Hi, I have an 09 plate mini cooper S, recently had my run flats replaced with standard tyres for an improved drive which has worked really well however I am having issues with the tyre pressure warning light. It was reset at the time but comes back on almost every time I drive. Unlike when I have had a flat tyre previously with the run flats, it does not require reseting to get rid of it, when I restart the car it has gone but then may come back on a day or so later. Taken it back to the garage who have checked for faults by running a diagnostic but nothing has shown up, they have reset it again but it continues to happen. Now that I don't have run flats and obviously don't have a spare wheel, I need to be able to rely on the warning light. Can anyone help?
KellyD is offline
post #5 of 5 (permalink) Old Mar 24th, 2019, 09:58 PM
Quoted: 600 Post(s)
check tyre pressures first off, also check all tyres are same size ie no one has accidentally put a 55 profile on a 60 profile set maybe, the car works out whether a tyre is flat by using the abs sensors and abs system for its readings,, ie a low/flat tyre has a smaller rolling area to it,, might be a abs sensor intermittent fault kicking it off,, not all software will detect deep p-codes dealer only so might need a dealer visit to cure it..
i would carry some tyre foam around in the boot just in case of punctures, link below for idea
https://www.ebay.co.uk/itm/3-x-Quick...2200a0d27987d8
Albert Einstein: The definition of insanity is doing the same thing over and over and expecting different results.
mike1967 is offline
Run flats versus non-run flats tceditor Wheels, Tyres & Brakes 10 Apr 26th, 2006 09:49 AM
Run Flats vs Non-Run Flats edwin_mini Wheels, Tyres & Brakes 11 Oct 22nd, 2005 05:47 AM
Replacing run flats with non run flats? minifrog Wheels, Tyres & Brakes 2 Oct 24th, 2003 04:14 AM
SS with 17" run-flats, vs SS+ with 16" run-flats. Prowse First Generation MINI Cooper 22 May 22nd, 2003 12:36 AM
Run Flats or Non Run flats OWLS11 Wheels, Tyres & Brakes 6 Mar 14th, 2003 10:11 PM
