This is a belated reply to an old thread that briefly mentioned how much energy is really used in spinning up the tires to 60 mph, to garfield’s lightweight wheel road test, and to those estimating the accelleration improvement from removing a pound from the wheels compared removing a pound from the chassis.
Some, but not all, of the work in getting the car to 60 is giving it translational kinetic energy (TKE). This is the energy of the whole car plunging straight along at 60 ignoring anything rotating, say like it was skidding on frictionless ice with the engine off. Some more of the work, but not all the rest, is giving rotational kinetic energy (RKE) to the wheels and tires. (I’m also going to do these calculations for engine flywheels and post on the performance forum.) Since work = power x time, if you reduce the work required by reducing these energies, you get to 60 faster.
First, I’ll compare 1 lb on the car with 1 lb on a wheel:
The TKE = 1/2 x the mass x (velocity squared). For a 1 pound mass (lbm) on the car going 60 mph (= 88 ft/sec), the required TKE = [1/2] x 1 lbm x (88 x 88) ft ft / sec sec = 3872 lbm ft ft / sec sec
The RKE = 1/2 x the rotational inertia x angular velocity squared. The rotional inertia (RI) = mass x (radius squared). The angular velocity (w) is in radians = rev/sec x 2 pi radians/rev.
Assuming that the wheel and tire mass is lumped at a diameter of 18” (= radius of .75 ft), a 1 lbm on the wheel has an RI = 1 x (.75 squared) = .562 lbm ft ft.
With a tire circumference of 76” (= 6.33 ft), 88 ft/sec is 13.9 rev/sec. w = 2 x pi x 13.9 = 87.3 rad/sec
So RKE = 1/2 x .562 lbm ft ft x 87.3 x 87.3 / sec sec = 2143 lbm ft ft / sec sec.
Taking 1 pound off a wheel saves both TKE and RKE. But the ratio compared to taking a pound off the chassis is only 1.6 = (3872 + 2143) / 3872. That is, taking 1 pound off a wheel is the same as taking 1.6 pounds off the chassis FOR THE PURPOSE OF ACCELLERATION. Sorry, but guys hoping for 5 sec. 0-60 times by lightening the wheels and tires just aren’t gonna make it...
As a sanity check, let’s see how this works with Garfield’s lightweight wheel test.
Assuming a car weight of 2800 lb and a weight of 200 lb for his set of 17" s-lites and runflats, the calculations above give that the wheel and tire RKE is an additional 4% above the TKE to get the car to 60. (For just doing a ratio, you can use the weight in pounds instead of the pounds in mass. The pounds weight ratio is 430,000/10,842,000. And no cracks from the Newton-kilogram-meters/sec guys)
Garfield saved 11 lb per wheel and, I’m guessing, 2 lb per tire, for a total savings of 52 lb. This reduces the TKE required by 52/2800 = .019 = 1.9% He also saved 52/200 of the 4% wheel and tire RKE, for another 1% savings. With a total savings of 2.9%, the reduction from his 'stock' 6.9 sec time should be about .029 x 6.9 sec = .2 sec.
Which is just what he did....LOL I guess he's not a national level driver(champ?) for nothing, since “he got all that Mother Nature offered”
An aerospace coworker once told me "You may choose to ignore the laws of physics, but the laws of physics never ignore you." I add "But sometimes you just do the math wrong or pick the wrong law...."
